  • SN95 4.6L Mustang Tech
Installed Pro5.0 Shifter Today-Something Wrong
  • Thread starter Thread starter TweekedGT
  • Start date Start date Sep 18, 2004
TweekedGT
1,274
Alberta
Sep 18, 2004
  • Sep 18, 2004
I just got my pro 5.0 shifter today and I was excited to put it in. Now that I have it installed it feels tougher to shift. It is a shorter throw but as you pass through neutral to get to the next gear it feels tighter and not as smooth. Is there a breakin period for these or did i just tighten some bolts too tight? I really think it should be much smoother than it is. Did I screw up somewhere? Help please.
nickthegenius
1,631
Elwood, IN
Sep 18, 2004
  • Sep 18, 2004
Mine was the same way. The feel gets better over time.
w00t
334
Arlington TX
Sep 18, 2004
  • Sep 18, 2004
Check the stop bolts.
TweekedGT
1,274
Alberta
Sep 18, 2004
  • Sep 18, 2004
I don't think it would be the stop bolts. It's before I even get to them that it feels tight. I am worried i might have tighten the 4 main bolts that bolt the shifter to the tranny too tight and they are jamming the shifter into the tranny too hard, if that makes any sense.
squares98
852
Orange,ca
Sep 18, 2004
  • Sep 18, 2004
thats normal for the break in period, just drive it and it will lossen up a little.
R
raykrv6a
153
Maple Grove, MN
Sep 18, 2004
  • Sep 18, 2004
The short handle that comes with it makes it seem that way. I went to a Tri-Ax handle and it's perfect for me. Longer handle give more leverage and less effort.
TweekedGT
1,274
Alberta
Sep 18, 2004
  • Sep 18, 2004
Thanks guys! I was a little worried there. I'll give it some time to break in.
nickthegenius
1,631
Elwood, IN
Sep 18, 2004
  • Sep 18, 2004
I almost forgot about changing my handle. The original stubby POS really makes the "notchiness" stand out more. That was the best thing I did to my Pro 5.0 is adding this handle:
http://www.mgwltd.com/mustang_shift_handle.html
Dr. Wu 2000
554
Eastern, Pa.
Sep 18, 2004
  • Sep 18, 2004
If you are using the handle that comes with the pro 5.0 you need to change that pronto. That handle is too straight up and down. There are many good handles out there that will fit the 5.0. I have the UPR trick stick, you can go with the Steeda handle, MGW makes a nice piece. Check them all out and go with one.
J
jbrown
393
Tallahassee, FL
Sep 19, 2004
#10
  • Sep 19, 2004
  • #10
try oiling it if its still hard to shift in a week or two.
GOLDENPONY
1,503
LOVELAND, OHIO
Sep 19, 2004
#11
  • Sep 19, 2004
  • #11
Pro 50
I agree with raykrv6a, I went with the Pro 50 with the Tri Ax handle-perfect!
xseler8
619
Montgomery County,Pa.
Sep 19, 2004
#12
  • Sep 19, 2004
  • #12
Call pro 50..they'll talk you thru it. My pro50 w/short handle was crisp & fast from the start..no break in should be needed. Also,is it the correct shifter for your Stang. I know someone that installed the wrong model. hth
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
