  • 1994 - 1995 Specific Tech
installing 03 cobra front a-arms.
  • Thread starter Thread starter robertdale
  • Start date Start date Sep 30, 2005
R
robertdale
382
kentucky
Sep 30, 2005
  • Sep 30, 2005
I just got my 03 cobra front a arms today. They were $175 shipped. Comes with new ball joints and bushings. Also at the same time I am planning to replace the tirod ends and rack bushings. Anything I need to know before I tear into it?
WhiteDevil
2,717
San Diego
Sep 30, 2005
  • Sep 30, 2005
Not sure, but let us know how it goes, maybe with pics, i might be doing something similar to mine.
TrueBlue95GT
966
Connecticut
Oct 1, 2005
  • Oct 1, 2005
Mark your old tie rod ends before you take them out so that you can match the new ones when you put them in. At least you can drive to the alignment shop without any problems if you do that.
BLT2BTU
24
upstate NY
Oct 1, 2005
  • Oct 1, 2005
whats the benefit of the 03 arms?
yellowstang1994
338
  • Oct 1, 2005
Hi, i'm planning on doing this very soon... Seeing as my balljoints and tierod ends are bad.
BLT2BTU - The advantage of 03 cobra a-arms are that it gives you a 10% more steering radius. On top of that you get the high friction balljoints and better arm busings already assembled. Say your balljoints went bad and you were going to replace them. you'd have to take them out and press new ones in. Usually shops charge near $500 for work like that. What I'm doing is getting the 03 a-arms with everything already assembled and doing the install myself.
robertdale - i'm doing the install myself and it seems pretty straight forward. you already know about taking the spings and shocks off. Just be careful with that. Probably the hardest part is getting the old a-arm off, lol. Good luck, and let me know how it goes or if you'd do anything different. If you have time maybee even a small write up? Good luck again!
R
robertdale
382
kentucky
Oct 1, 2005
  • Oct 1, 2005
Yea I'll tackle it in the morning. I'll do a little write up when I get it going good and get to the alignment shop.
juiced_94gt
1,143
Southern California
Oct 1, 2005
  • Oct 1, 2005
let's us know if they really "significantly reduce impact harshness" as it states in the jegs cataloge, in very curious about this, also see if the car feels different then with stock arms, by the way, where did you buy them from?
bimmertech
1,123
merriam, ks
Oct 1, 2005
  • Oct 1, 2005
i bought mine from downs ford about a year and half ago. as far as impact harshness goes, i cannot comment as i did springs struts cc plates all at the same time.
R
robertdale
382
kentucky
Oct 1, 2005
  • Oct 1, 2005
Well I got the passenger side on this evening. It went pretty smooth only problems were I had to cut the ball joint nut off because it would just spin with the joint. Also I had a heck of a time getting the spring back in the car. Are there any tricks to getting the spring in any easier? I bought the arms from http://www.oemfordparts.com/
Ordered them on monday got them thursday.
juiced_94gt
1,143
Southern California
Oct 1, 2005
#10
  • Oct 1, 2005
  • #10
if their stock springs your gonna need a spring compressor, or a really big prybar which is what i used to use at the bodyshop, if you have lowering springs you just need to push down on the arm and push it in...MAKE SURE YOU TIGHEN THE CONTROL ARM BOLTS WITH THE CAR AT RIDE HEIGHT(WHITH IT'S WEIGH ON THE TIRES) OR YOU WILL CAUSE BIND..THE ARMS SHOULD MOVE FREELY UP AND DOWN WITH THEIR OWN WEIGHT WHEN THEY ARE TORQUED DOWN TO 180 FT. LB.
R
robertdale
382
kentucky
Oct 1, 2005
#11
  • Oct 1, 2005
  • #11
Yes I have stock springs and they are a pain to get back in. A big pry bar and alot of pushing finally got the spring in. I believe I'll try to find some way to compress the spring on the side I havent done yet.
95COBRA241
339
Delray Beach, FL
Oct 1, 2005
#12
  • Oct 1, 2005
  • #12
Are these actual a-arms for an 03-04 cobra or are they a modified part with the cobra bushings and low friction ball joints?
R
robertdale
382
kentucky
Oct 1, 2005
#13
  • Oct 1, 2005
  • #13
They are the actual a arms for the 03 cobra.
R
robertdale
382
kentucky
Oct 2, 2005
#14
  • Oct 2, 2005
  • #14
Got it all together this morning and went for a test drive. The car is much smoother and more responsive now. I noticed my old bushing were cracked and looked bad. I never imagined it would smooth things out so much. Instead of a hard bump on potholes It is just a smooth dip. Well worth the money...
WhiteDevil
2,717
San Diego
Oct 2, 2005
#15
  • Oct 2, 2005
  • #15
Did you get it aligned yet? Does it change the wheel base at all? I thought i heard that somewhere.
R
robertdale
382
kentucky
Oct 2, 2005
#16
  • Oct 2, 2005
  • #16
No I didnt get it aligned. It seems fine as is. I didn't change tie rods yet so I am waiting till this week when I change the tierods and steering rack bushings before I get it aligned. Don't know about wheel base yet I'll look this evening.
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Oct 2, 2005
#17
  • Oct 2, 2005
  • #17
I got these same A-arms installed a couple months ago. All my other suspension stuff was put on over a year ago and the overall ride was good, but much harsher than stock. With the new Cobra arms, the ride is very much improved. Any sized bump is simply soaked up.
I've got H&R Race Springs, so the ride was instantly harsher, but fine for daily use. Now with the new A-arms, my ride easily rivals the smoothness of the stock feel AND I have all the handling benefits of my suspension upgrades.
Definitely get a good alignment after this install. Alignment was no problem. I couldn't be happier with the results. Now I am really glad I went with the Race Springs.
I recommend this upgrade for anyone with high miles.
95COBRA241
339
Delray Beach, FL
Oct 21, 2005
#18
  • Oct 21, 2005
  • #18
Thanks to your thread, I went and ordered a set fron Bleakley Ford (best price I could find). Installed them today and what a difference. However, I have to be honest, the bushings and ball joints were so bad I am sure a new set of stock arms would be just as good. The ride is like when the car was new. I don't know what the 10% steering ratio is supposed to feel like, but the car rides real good. Thanks!:SNSign:
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
