  • SN95 4.6L Mustang Tech
Installing Cast & Camber Plates
  • Thread starter Thread starter BlackenedSVT
  • Start date Start date May 13, 2005
BlackenedSVT
1,841
New Jersey
May 13, 2005
  • May 13, 2005
Next weekend I will be installing my Tokico Adj (front) Struts, Eibach Lowering Springs and STEEDA C/C Plates. I have tech articles on how to install the springs. And I think the shocks are pretty straight foward, and I'll set them to setting "3" for the street.
However, how do you install the Cast & Camber plates. When taking all of my factory pieces (of these 3 to be replaced...) which should I take off first? And which aftermarket piece (the CC plates, springs or struts) should go BACK ON FIRST??
I'm guessing...jack the car up, take the wheels off, take the springs off first, then the shocks...then install the NEW c/c plates, then the tokico struts, then the lowering springs...
I know the C/C plates adjust the Camber and Toe of the wheels. But I hear that you need an alignment after you lower the car.
1. How do you adjust the C/C plates?
2. What settings are factory?
3. What settings do I want my aftermarket CC plates to be at?
4. Will I need any additional pieces, like X2 Balljoints from STEEDA for this lowering?
Any advice would be appreciated... ...for ANY of these 3 mods...
EDIT: Is it a problem that I only have adjustable FRONT struts, and will be re-using my factory REAR shocks???
00redGT
72
Central Ohio
May 13, 2005
  • May 13, 2005
Even though this isn't Steeda, I suggest reading this:
MM Caster / Camber plate installation
It's the how-to, what, and why to installing Maximum Motorsports plates, which are essentially the same thing.
I'm about to do the same work (different parts). After talking with MM techs, they say not to worry about the extra pieces. All you need are the plates, springs and struts/shocks.
I'm paraphrasing, but they said that you shouldn't need any of the other stuff on a street car, even after lowering it with my H&R SuperSports. Bump-steer shouldn't be a problem and you shouldn't have to worry about it unless it is really bad, for some reason, on your car. They actually recommended to me that I don't spend my money on these additional items that they sell.
Hope this helps.
twogts4us
4,188
12
79
Dunedin, FL
May 13, 2005
  • May 13, 2005
The allow adjustment of your caster and camber, nothing to do with the toe. Not trying to bust your balls, but understanding what these do will really help you with the install process. Best of Luck!
ToplessStang
591
Montreal, Canada
May 13, 2005
  • May 13, 2005
I`m putting in my H&R`SS, MM C/C plates and Mach 1 shocks/struts this weekend. Let`s hope I can get out of my inclined driveway when I`m done . Does anyone have specs for a better alignment setting with the new C/C plates ? Thanks.
M
mijo_latino
179
Canton, Michigan
May 13, 2005
  • May 13, 2005
i did my c/c not long ago. The best info for specs is on Modular Depot forums. Do a search on the site.
Basically, for a conservative alignment you want .7-1 deg negative camber, maxed out positive caster, and .00625"(1/16") total toe in.
A more aggresive alignment is ~1.5 deg neg camber, max caster, and i'm not sure of toe in.
The people who did mine put .16" on each side, which i meant 1/16" total toe in, so im not sure if its a good thing.
The factory specs for the 98 are:
-1.35~.15 camber
2.45~3.95 caster
0~.12" toe in each tire.
Hope this helps. Double check these #'s with others, i could be wrong.
00redGT
72
Central Ohio
May 14, 2005
  • May 14, 2005
Yes...read page 4 of the pdf I posted. That'll give you a few recommendations and reasons why.
00redGT
72
Central Ohio
May 14, 2005
  • May 14, 2005
for more info on the basics, you should also read this:
http://www.miracerros.com/mustang/t_suspension.htm
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
