installing distributor
  • Thread starter Thread starter ponyboy01
  • Start date Start date Jun 27, 2007
P
ponyboy01
  • Jun 27, 2007
I installed a cobra intake yesterday and I yanked the distributor without marking it. Needless to say the car runs like crap now. Other than bolting stuff on im not that car savvy. Can somebody shed some light on how to put this thing back in correctly?
TrophyHead
1,195
11
49
PA
Jun 27, 2007
  • Jun 27, 2007
You have to get the #1 cylinder to top dead center. I shove a rag in the spark plug hole and turn the crank pulley. When the rag pops out your there. Then you have to put the rotor on the dizzy to the #1 point on the cap. I think it is around 1 o'clock position but check where your #1 plug wire is going. And align the rotor to that area. Then put a timing light on it.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 27, 2007
  • Jun 27, 2007
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block.
The distributor starts out with the #1 plug wire lined up at about 12:00 with you facing it. Align the rotor to about 11:00, since it will turn clockwise as it slides into place.
Align the distributor rotor up with the #1 position marked on the cap, slide the distributor down into the block, (you may have to wiggle the rotor slightly to get the gear to engage) and then note where the rotor is pointing. If it still lines up with #1 position on the cap, install the clamp and bolt. If not, pull it out and turn 1 tooth forwards or backwards and try again. Put the #1 spark plug back in and tighten it down, put the clamp on the distributor, but don't tighten it too much, as you will have to move the distributor to set the timing. Note that if it doesn't align perfectly with #1 position, you can turn the distributor until it does. The only problem is that if you are too far one way or the other, you can't turn the distributor enough to get the 10-14 degree optimum timing range.
At this point hook up all the wires, get out the timing light and start the engine. Set the timing where your car runs best. Don't forget to disconnect the SPOUT jumper connector when you set the timing, and plug it back in when you finish.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 27, 2007
  • Jun 27, 2007
jrichker said:
Putting the distributor back in is fairly simple. Pull #1 sparkplug, put your finger in the sparkplug hole, crank the engine until you feel compression. Then line up the TDC mark on the balancer with the pointer on the engine block...
Couldn't have said it better
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
Instead of putting the rotor at 12 oclock. I like to put mine at 11 oclock. Gives u more room to advance without the connector hitting the water neck
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
