You have a few options for the water temp.
1. Buying radiator hose adapter
http://cgi.ebay.com/ebaymotors/32mm...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Something like this.
2. There is drain on the side of the block.
3. Get your coolant crossover tapped and threaded, assuming you have the metal crossover.
The volt gauge you can either attach directly to the battery or the volt outlet under you radio next to the trac control. Those are the easiest for me.
For the lights you need to get an "Add-A-Fuse" and find out what fuse your dimmer switch is operating on, so you don't have to splice into some wiring.
