Installing gauges. Sender question.
The oil loss will only be a couple of spoons worth of oil. The coolant loss will depend on where you place the sender. If you are using the stock location, remove the radiator cap & eyeball the coolant level. If it is the same number of inches or higher than the sender, you may want to drain a little. if it is lower then you wont need to drain any. If you have the new sender all prepped with Teflon tape or sealant on the threads and are real quick, you might not spill more than a cup full anyway. Be sure to wash the driveway down good when you finish - dogs & cats will lick up the spilled coolant and it is poisonous to them.
