  • 1994 - 1995 Specific Tech
Installing push button ignition, need help!!!
  • Thread starter Thread starter Black95GTS
  • Start date Start date Jul 18, 2004
Black95GTS
1,644
Marlborough, MA
Jul 18, 2004
  • Jul 18, 2004
Alright, this is my plan. I'm gonna run a wire from the clutch safety switch so that when the clutch is depressed, the wire goes "hot." The wire will then run into a push button that I'm going to mount in the ash tray compartment console. From the button a wire will run through a 12V Zener diode and be spliced into the starter solenoid. Basically, I'll get in the car, depress the clutch, turn the key one click up, then press the pushbutton to activate the solenoid and crank the starter.
My questions are:
Does anyone think this won't work, and why not?
Can I get at the clutch safety switch from the top or do I have to jack up the car, and where the heck is the damn thing?
I realize that when you crank the starter via the normal ignition, it shuts off all the accessories to take it easy on the battery. If I wire it up as I mentioned, the accessories would still be on when the battery turns the starter. I'm concerned that all the accessories plus cranking it might be too much for the battery. Do you think this would impact the starting in any way?
thanks for your help!
Adam
Black95GTS
1,644
Marlborough, MA
Jul 19, 2004
  • Jul 19, 2004
ttt
MehakGT
544
Toronto, Ontario, Canada
Jul 19, 2004
  • Jul 19, 2004
I'm thinking of installing one as well, good questions about the battery - I'd like to know as well.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
