Installing shocks at home
  • Thread starter Thread starter vristang
  • Start date Start date Aug 7, 2006
vristang
4,933
101
124
Seattle
Aug 7, 2006
  • Aug 7, 2006
I have new springs and front shocks for the 4 cyl. The suspension is in pretty dire need.
No local shops will install parts not purchased through them.
What tool do I need to remove and install the nut on the strut tower?
(I dont' even know what to call it other than "that tool for removing the front shock")
Once I get everything installed I can drive down for an alignment.
thanks,
jason
88gt
794
Drillers cabin
Aug 7, 2006
  • Aug 7, 2006
If the 4 pot has struts on it similar to the v8 cars, I used an impact with a socket to remove/install mine ant the c/c plates..at the spindle, used a big damn wrench and socket with a long breakover bar to remove/install.
Jim
GreatWhite
232
Fairfield, PA
Aug 7, 2006
  • Aug 7, 2006
pretty much going to need an impact gun to get the top bolt... and like 88gt said, a big ass breaker bar for the other bolts.
vristang
4,933
101
124
Seattle
Aug 7, 2006
  • Aug 7, 2006
So using an impact gun will overcome the issue of the strut simply rotating with the nut?
I messed with it the other day and the strut just rotated with the nut.
I have an impact gun, so no biggee. It just seems like the top shaft of the strut will keep rotating.
Thanks for chiming in dudes
jason
88gt
794
Drillers cabin
Aug 7, 2006
  • Aug 7, 2006
If you can get a pair of vice grips on the strut rod through the wheel opening, that will help keep it from rotating on you on removal. On installation, just hit it with the impact gun and you are set.
use a sharpie to mark where the c/c plates are located as a reference at install of new struts if you have to move them.
Jim
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Aug 7, 2006
  • Aug 7, 2006
I have been able to remove the nut a couple of time by merely putting a floor jack under the control arm and putting weight on the strut. This will take some of the weight off the top nut. It's worth a try but the "best" way to do it is with an impact.
RYC CUKR
1,437
Orlando
Aug 7, 2006
  • Aug 7, 2006
On my struts there was a slot in the top of the threaded stud bolt and I used a very large screwdriver in the slot and a big wrench to break the nut loose. Worked like a champ for me.
sunil6784
620
Boston, MA
Aug 7, 2006
  • Aug 7, 2006
I did it with two people, one person held the strut between their legs and hands, and the other hit it hard with the impact gun.
M
mkk50
109
29
39
Aug 7, 2006
  • Aug 7, 2006
if ur throwin away the old struts and dont have an impact, i did mine by clamping a pair of vice grips on the rod, and i mean clamping, i jumped on the handle to close them, and then just hold them and loosen the nut, it was easy after that. For the new ones i just used a screw driver in the slot and stuck it in between the hood hinge and the fender and tightened the nut down
HISSIN50
34
129
Aug 8, 2006
#10
  • Aug 8, 2006
  • #10
Good thoughts. Also, you dont need to mess with the stock camber plates (using the term very loosely) - just remove the center nut that everyones' talkin about.
If you're real worried about the top strut nut (a 5 hp, 25 gallon air set-up should bust it loose, but I REMEMBER that Seattle corrosion), you can have a shop (or buddy with a big compressor if you dont have one) blap them loose for you. Hit the threads with some antiseize and tighten them back up just enough to get home safely - they should come off easy next time.
Then again, as someone said, if it has shocks up front, I doubt ANY of that is an issue. Generally speaking doing shocks goes pretty fast.
Good luck Jason.
vristang
4,933
101
124
Seattle
Aug 8, 2006
#11
  • Aug 8, 2006
  • #11
I want to say thanks for all the responses
:SNSign:
I have a new Cat being installed tomorrow, and I'll do the struts and springs Thurs.
I don't think I will have any problems now.
JT-
yeah, all this rain can be pretty tough on a car. The only upside is they don't salt the roads much.
After doing some light exhaust work on this car, I am amazed at how clean the undercarriege is.
I'll be doing the work in the old mans garage, so I do have a fairly large compressor. I don't remember the capacity, but it stands nearly 4ft tall!!!
Nothing like overkill huh?
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
  • dan50
  • Jul 18, 2026
dan50
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
