Intake Height
  • Thread starter Thread starter Cobain03
  • Start date Start date Jul 24, 2006
Cobain03
996
Lexington, Ky
Jul 24, 2006
  • Jul 24, 2006
is there a height difference between the performer and performer RPM (non air gap) manifold? i have low clearence as it is and if its any taller then i'd have a problem.
D
D.Hearne
11,730
south louisiana
Jul 24, 2006
  • Jul 24, 2006
Look it up on Edelbrocks website. They have the dimensions there. Pretty sure the RPM is about 1" taller.
Cobain03
996
Lexington, Ky
Jul 24, 2006
  • Jul 24, 2006
guess it looks like i will be staying with the little ole performer.
D
D.Hearne
11,730
south louisiana
Jul 24, 2006
  • Jul 24, 2006
You can always go to a low profile aircleaner base to compensate. I don't see why you have a problem with clearance unless you've got a really tall filter.
bad68coupe
220
Richardson, TX
Jul 24, 2006
  • Jul 24, 2006
Yes, i am afraid of teh same thing, if i have a stock 302 in a 68 coupe witha RPM intake and a 1406 CArb will i clear the hood?
Cobain03
996
Lexington, Ky
Jul 24, 2006
  • Jul 24, 2006
well i have several things going against me. jacke dup mounts to accomadate for headers, and my hood scoop has bolts through the hood thats 10 foot long.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 24, 2006
  • Jul 24, 2006
10 foot long bolts?!!!
D
D.Hearne
11,730
south louisiana
Jul 24, 2006
  • Jul 24, 2006
Well on my 67 with the 390 and later the 427, it all fit under the hood. 390 and 427 with the MR427 intake, Holley carb and 289 Hi-po aircleaner with about a 2-1/2" tall filter. Later had the Low riser dual 4's with Holley 600's and the factory cast aluminum aircleaner and 2" filter. Only when I decided to stack 2 filters on that did I cut the hood.
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
J
SN95 Hello new to this app
  • James S
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Habu135
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
