  • 1994 - 1995 Specific Tech
INTAKE HELP ??
  • Thread starter Thread starter howiefisher
  • Start date Start date Mar 8, 2008
howiefisher
154
Ont Canada
Mar 8, 2008
  • Mar 8, 2008
what would be the best upper and lower intake to get for a stock motor ????trick flow track heat ??
R
red95gtconvert
382
Ponca city, OK
Mar 8, 2008
  • Mar 8, 2008
A cobra or street heat would work well.
RIO5.0
6,892
N.H.
Mar 8, 2008
  • Mar 8, 2008
If monies tight...port the stock lower /upper...Theres a noticable change and its cheap money. A 95 Cobra would be an easy swap...no extra chit to buy.
Venom351R
4,548
41
98
MAINE
Mar 8, 2008
  • Mar 8, 2008
Used Cobra's can be found for cheap. If you dont want used or a cobra Id go w/ the Street Heat.
Stanger007
2,015
Baton Rouge, LA
Mar 8, 2008
  • Mar 8, 2008
The Cobra is hard to beat. Get TMOSS to port it.
Here's some pics of mine after I got it back from him: http://www.flickr.com/photos/wesratcliff/sets/72157602278334751/
Wes
Dino Dino Bambino
1,673
90
79
Cyprus
Mar 9, 2008
  • Mar 9, 2008
If you're planning to change the heads/cam later on, I suggest you buy a new intake with the heads/cam and install everything in one go. In the meantime, you can either port the stock upper/lower intakes yourself or send them to Tmoss. I did it myself and I also ported my stock heads with excellent results.
howiefisher
154
Ont Canada
Mar 9, 2008
  • Mar 9, 2008
how much hp do you think i will get off the street heat ?? and yes i am going to put in a cam while i have it apart but the heads will not go on till the end of summer ?what do you guys think about a 100 shot of nos it seems likw cheap power
howiefisher
154
Ont Canada
Mar 9, 2008
  • Mar 9, 2008
i know were i can get a used street heat for $350 is that going to be better then 94/95 cobra intake ???its going for $500 used thanks guys .
earleys94gt
1,223
Ashley, Ohio
Mar 9, 2008
  • Mar 9, 2008
If you can get the Street Heat for that price, assuming it's both upper and lower intakes, then I would go that route. One thing to remember about the Street Heat is the throttle body opening is 75mm. Just FYI. You'll also need the intake elbow adapter.
The cobra, as stated above, already has the extra things on it. This is a good intake but if you plan on getting afternarket heads and a cam down the road, this may not be the intake to get. You don't want to buy parts twice.
Venom351R
4,548
41
98
MAINE
Mar 9, 2008
#10
  • Mar 9, 2008
  • #10
You will get better power from it once you have better heads. 100 shot is quick easy power but its up to you. Personally I hate nitrous.
Yeah dont forget about the adapator. They run about $98.00, but the Cobra intake already has the elbow bend in it.
It all comes down to what kind of power you want to make w/ the car. What size heads to you plan on putting on it?
howiefisher
154
Ont Canada
Mar 9, 2008
#11
  • Mar 9, 2008
  • #11
well then i will get the trick flow .how do i know its the street heat ?he says it is and thats all i need is the elbow there like $90 buck s right i can still use my stock throttle bodie right .it will fit under my stock hood and strut brace
earleys94gt
1,223
Ashley, Ohio
Mar 9, 2008
#12
  • Mar 9, 2008
  • #12
The Street Heat has a powerband of idle-5500.
The Track Heat's powerband is 1500-6500.
To be for sure you are getting the Street Heat, you can find the part number and then look on www.summitracing.com to see which one it goes too.
You can, but the opening is 75mm so the stock 60mm will be restrictive. You can always upgrade later on to a 70 or 75.
I believe it does.
blksn955.o
3,263
st.louis mo 314
Mar 9, 2008
#13
  • Mar 9, 2008
  • #13
the bottle should put you in the low 13's...I ran a 125 shot on a 100% stock motor with pullies, gears, K&N, and a MSD digital6+ box. The car ran a 14.3 on motor and 13.1 at 107 on the 125 shot on $89 street tires. I have about 200$ in the n2o kit and had hardly any mods and hardly any money in the whole setup with a car that straight up shocked a few people.
If you are running the stock/unported E7 heads...anything more than 1.7rr on the stock cam is a waste. The cam will be a waste as when you do get better heads you will need one to better fit those heads. If you put the cam in to match those heads performance and drivability will suffer.
Venom351R
4,548
41
98
MAINE
Mar 9, 2008
#14
  • Mar 9, 2008
  • #14
The brace Im not sure, the stock hood yes it will fit.
howiefisher
154
Ont Canada
Mar 9, 2008
#15
  • Mar 9, 2008
  • #15
i went to summit but they dont have a listing for the street heat ??/have they changed the name
earleys94gt
1,223
Ashley, Ohio
Mar 9, 2008
#16
  • Mar 9, 2008
  • #16
Yeah, sorry, it's now called the Sreet Burner.
D
DavidNC
119
#17
  • Mar 10, 2008
  • #17
I submit that the explorer intake will be the best for a stock motor. I read through a intake compare article in allformustang.com, in technical article section, which clearly showed that below idle to 5500 rpm was best served by the explorer, cobra, Gt-40 intakes. The eldebrock intake seemed for applications of 1500-7000rpm.
hollywoodstang
1,095
Mar 11, 2008
#18
  • Mar 11, 2008
  • #18
Who is this tmoss guy? and where can i send it in to get it ported? i have FMS intake and i have not port anything in my car. does it really make that much difference? and how do i contact him? let me know. thanks
Stanger007
2,015
Baton Rouge, LA
Mar 11, 2008
#19
  • Mar 11, 2008
  • #19
Here ya go: http://www.tmossporting.com/
M
Upper intake oxidation
  • MadMatt7
  • Monday at 7:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 12:55 PM
rednotch
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
1994 - 1995 Specific Tech May 29, 2025
General karthief
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
