what would be the best upper and lower intake to get for a stock motor ????trick flow track heat ??
how much hp do you think i will get off the street heat ?? and yes i am going to put in a cam while i have it apart but the heads will not go on till the end of summer ?what do you guys think about a 100 shot of nos it seems likw cheap power
If you can get the Street Heat for that price, assuming it's both upper and lower intakes, then I would go that route. One thing to remember about the Street Heat is the throttle body opening is 75mm. Just FYI. You'll also need the intake elbow adapter.
The cobra, as stated above, already has the extra things on it. This is a good intake but if you plan on getting afternarket heads and a cam down the road, this may not be the intake to get. You don't want to buy parts twice.
The Street Heat has a powerband of idle-5500.how do i know its the street heat
You can, but the opening is 75mm so the stock 60mm will be restrictive. You can always upgrade later on to a 70 or 75.i can still use my stock throttle bodie right
I believe it does.it will fit under my stock hood and strut brace
