Intake install Problems, need advice
  • Thread starter Thread starter YawnY
  • Start date Start date Jul 31, 2010
1 of 2 Next Last
Y
YawnY
42
  • Jul 31, 2010
Alright so here my issue. I was supposed to be attending a track meet last night, but I had to install my gt-40 upper/lower before heading to the track. I got all my gaskets and a 1/2 spacer so the upper plenum could clear my ford racing valve covers. The spacer kit was from ford racing. I had the lower on and all torqued down to spec but when installing the upper with the spacer the bolts provided in the kit were to short.
I don't know if any of you have experienced this but how long of a bolt is required?
Cobra912
1,777
11
39
Wish I was anywhere but here
Jul 31, 2010
  • Jul 31, 2010
That's weird. Should have had the right bolts included with the spacer. What brand? New?
Vinnietbird
584
  • Jul 31, 2010
Add 1/2 inch to the factory bolt length and head to Lowe's and grab the bolts you need.
Y
YawnY
42
  • Aug 1, 2010
I think the kit that was ordered was for a cobra intake, might be why the bolts were alittle shorter from ford racing.
Don't have lowes up here in Canada so I might have to order these...
Cobra912
1,777
11
39
Aug 1, 2010
  • Aug 1, 2010
Home Depot or Rona might have them, I went to a place locally that sold just bolts and hardware, you'll probably find something close to you to get them.
Y
YawnY
42
  • Aug 2, 2010
Another issue that I am having, is that there is a coolant temp sensor mounted on the stock intake but not on the gt-40, will not having that temp sensor plugged in cause the engine to run rich?
Bryan83taco
554
40
39
SF Bay
Aug 2, 2010
  • Aug 2, 2010
Just drill and tap, I beleive it's a 9/16 drill and a 3/8 NPT tap.
Y
YawnY
42
  • Aug 2, 2010
It seems as there is another temp sensor on the right hand side of the engine, along a coolant tube that leads to the heater core, instead of drilling and tapping can I just splice in the wires leading to that temp sensor?
Coast2CoaStang
254
  • Aug 2, 2010
Here is a useful thread. http://www.stangnet.com/mustang-for...orer-gt-40-intake-thread-56k-dont-bother.html
Post #79, on page 4 Covers how to relocate the ACT sensor. Hope this helps
Y
YawnY
42
#10
  • Aug 3, 2010
  • #10
Thanks alot, I will try that and see how it work. Also with reguards to the coolant lines running to the egr any other way to route them?
fiveohwblow
Official Member
2,169
145
155
Aug 3, 2010
#11
  • Aug 3, 2010
  • #11
Had that problem twice, one with my cousins cobra intake he bought this year
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2010
#12
  • Aug 3, 2010
  • #12
Explorer intake swap.
I got mine off a 96 Mountaineer with the 19# injectors and 65 MM throttle body for $250.
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40 lower. You will have to take the manifold off the engine and put it on the workbench to drill & tap it. The ACT uses a 37/64" drill or 9/16" drill and a 3/8" pipe tap. See Industrial Supply Equipment from MSC Industrial Supply or McMaster-Carr if you can't find the drill bit or tap locally.
The next best spot for the ACT is the stock air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater I have. You don't need heat very often here in Central Florida...
The vacuum lines you need are 1 small line for fuel pressure regulator, 1 small line for A/C,1 small line for EGR and another small line for the smog pump. One big line at the back goes to the vacuum tree for the power brake & A/C, one big line goes to the PVC valve. The other big line goes out the front for the carbon canister. In a pinch, one of the small lines can connect to the spare port on the vacuum tree. Cap or plug the remaining lines since they aren't needed.
The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
This is what I did:
Make a drawing of the position of the old throttle body linkage arm and its angular position relative to the centerline of the throttle body. Remove the ball stud off the explorer TB to make way for the adapter plate. Drill and tap a 10-32 hole in the linkage parallel to the TB shaft. Make an angle bracket out of 1" angle iron 3/8", drill a 3/16” hole in the center of each one of the legs. Then bolt it on where the hole was drilled & tapped. Then make a circular adapter plate out of 1/4" thick aluminum to bolt the two linkage arms together. Then bolt the aluminum plate to the existing linkage, and the angle bracket. Next mount the arm with the ball stud off the old throttle body on the adapter plate using the drawing to get the angle correct. You will need an aircraft type countersink for one of the bolts that secures the plate to the explorer linkage arm. It ends up being under the arm with the ball stud for the linkage. It works great and looks neat.
The Explorer TB could have been real simple if I had a gas welding torch or taken the TB to a welding shop. Just grind the mushroomed part of the TB shafts so that you can pry the linkage arms off. Then swap the stock arm onto the Explorer TB and braze it onto the shaft. It Takes about 3 minutes or less worth of work with the torch, so it shouldn't cost much.
I didn't have access to a welder, so I fabb'ed the plate in my shop. I took about 1.5 hours to do it, it was a measure, cut, and fit type of operation.
Also see http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Diagram courtesy of Tmoss & Stang&2birds - Typical Vacuum Routing for a Fox stang 5.0:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Cut a piece of cardboard to fit the lifter valley and help catch all the crud scraped off the gasket surfaces. I suggest that you make good use of a shop vac while you are scraping and cleaning to avoid getting the old gasket material lost inside the engine. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken. Cut a piece of cardboard to fit the lifter valley and help catch all the crud scraped off the gasket surfaces.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out. Be sure to put a rag or cap in the block where you removed the distributor. It will save you trouble if something falls into the empty distributor hole.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface. Also use the weather strip adhesive on the side of the gasket that mates to the head. When you are done, the head surface and the gasket surface that mate together will have weather strip adhesive on them. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. TADA! no leaks, and no gaskets that shifted out of place.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( BWD - Home ) as being resellers of Borg-Warner parts:
Parts Plus - Premium Auto Parts & Accessories or Auto Value / Bumper to Bumper Quality Parts & Service - Home of the Aftermarket Auto Parts Alliance Group or Tires, Auto Parts Stores, Brakes & Automotive Parts | Pep Boys or Federated Auto Parts - Automotive Aftermarket
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Plan on doing an oil change within 2 hours of run time on the engine. This will get the debris and coolant out of the oil pan.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
fiveohwblow
Official Member
2,169
145
155
Aug 3, 2010
#13
  • Aug 3, 2010
  • #13
^clearly Dave's (darkwriter) instructor
Y
YawnY
42
#14
  • Aug 4, 2010
  • #14
Well I had to order the bolts from the states cause I couldn't find a supplier around here, they should be in by friday.
Y
YawnY
42
#15
  • Aug 13, 2010
  • #15
Alright. So here's a dandy **** up from Ford Racing.
Got another spacer kit ordered, told them I have the Ford Explorer intake, they sent me another spacer and told me the bolts were the right length. Waited 2 weeks for this thing and got it today. I drove down to the shop who ordered it for me and to our surprise the bolts for this spacer were an inch shorter then the original spacer. Same part# on the box, the box had not been opened before but somehow the bolts were shorter.
Phoned a guy in Calgary (that's in Alberta for the American's) told him the situation and he couldn't believe it. Monday were phoning Ford Racing and complaining and also sending pictures with the two different bolt sizes and the boxes showing the part#'s.
So were going to end up phoning all the local bolt suppliers and just getting the right sizes. Probably should of done this in the first place and would of saved me the hassle of trusting Ford.
Cobra912
1,777
11
39
Aug 13, 2010
#16
  • Aug 13, 2010
  • #16
where are you located?
Y
YawnY
42
#17
  • Aug 13, 2010
  • #17
Winnipeg. I know your on heights
Cobra912
1,777
11
39
Aug 13, 2010
#18
  • Aug 13, 2010
  • #18
nope. but you could try bolt locker
Y
YawnY
42
#19
  • Aug 14, 2010
  • #19
Yeah where I work doesn't have an account with them, so motion is going to order me some 7" bolts and hopefully that will work.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 14, 2010
#20
  • Aug 14, 2010
  • #20
Some threaded rod from Home Depot, Lowe's or Ace Hardware would have done the job nicely. The threads will pull out of the aluminum manifold before the threaded rod will break or strip.
1 of 2 Next Last
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
