  • SN95 4.6L Mustang Tech
Intake Manifold question?
  • Thread starter Thread starter Pennywise2
  • Start date Start date Nov 15, 2006
P
Pennywise2
Banned
May 16, 2006
1,379
  • Nov 15, 2006
Before taking off my intake manifold on my 96 GT.
How much coolant do you really have to drain?
Do you have to take off both coolant hoses on the radiator?
How much coolant is needed one gallon or so to replace
what was drained?
Thanks.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Nov 16, 2006
  • Nov 16, 2006
just open the drain plug on the bottom of the radiator, and then loosen the coolant cap, that will drain the system out for you. you will need atleast 1 gallon to refill it. most of the time I use about 1 and a half.
P
Pennywise2
Banned
May 16, 2006
1,379
  • Nov 16, 2006
Thanks for your help Mike.
Mike97gt
it doe snot
10,633
Nov 16, 2006
  • Nov 16, 2006
no problem
stangGT97
1,299
Boston area, MA
Nov 16, 2006
  • Nov 16, 2006
This is exactly what I did. I bought three gallons of coolant to refill, ended up using a little over two if I remember right (once the air pockets were gone). Anyway if you drain it the way Mike said, you won't leak any out when you pull the manifold off.
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
H
Electrical 2003 GT convertible battery drain
  • Huggybear56
  • May 31, 2026
SN95 4.6L Mustang Tech May 31, 2026
Bronco2fan
