  • 2005 - 2009 Specific Tech
Intake Obstruction Remove
  • Thread starter Thread starter rich8566
  • Start date Start date Jun 22, 2005
rich8566
120
NY
Jun 22, 2005
  • Jun 22, 2005
I finally got around to removing the hydrocarbon obstruction in the intake. No problems so far. My Gt was an early October build. Any comments?
N
newbee90gt
32
Oceanside,Ca
Jun 22, 2005
  • Jun 22, 2005
any pics...just curious on what you are talking about and is this only in the GT's?
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Jun 23, 2005
  • Jun 23, 2005
heres a link to a thread on page 2: http://forums.stangnet.com/showthread.php?t=555710 theres a pic on there and more information on this topic....
rich8566
120
NY
Jun 23, 2005
  • Jun 23, 2005
I don't have any pics, but if you can imagine a can of Bud cut in half and filled with concrete you'd have a good idea of the size, look, feel and weight of this lovely item. Oh, and the concrete interior has holes like swiss cheese.
Out with that nasty obstruction - in with clean ariflow and more power!
D
delurker
169
  • Jun 23, 2005
Hatchman
86
Pensacola
Jun 24, 2005
  • Jun 24, 2005
rich8566 said:
I finally got around to removing the hydrocarbon obstruction in the intake. No porblems so far. My Gt was as early October build. Any comments?
Any comments? October? You should have took it out long ago.
BlazerLT
29
  • Jun 26, 2005
You sure it isn't intended for straightening the air flow path for proper MAF sensor readings?
AvalancheSVT
573
37
49
Jun 26, 2005
  • Jun 26, 2005
straightening airflow? dude, its air... it goes where you pipe it.
frdtch05gt
9
Algonquin, IL
Jun 26, 2005
  • Jun 26, 2005
I've had mine out for a few months now, no issues, haven't really felt any difference either.
bashed1
9
#10
  • Jun 26, 2005
  • #10
The factory quit installing the HC traps about 4/11/05. (Mine was built 4/29; doesn't have one.) Unless they simultaneously changed the flash software (which I don't know if they did or not) when they ceased installing the traps, you shouldn't have any problem if you remove one.
rich8566
120
NY
Jun 27, 2005
#11
  • Jun 27, 2005
  • #11
It's not possible that it is straightening the airflow since there is no direct routing of air through the thing. Now, maybe it was designed to have minimal impact on airflow, but it's hard to see how a one pound, half-can of Bud with cement inside does that!
F
Ford Tech
#12
  • Jun 29, 2005
  • #12
carbon trap
If you have the carbon trap, remove it. It was originally designed to catch fuel vapors escaping from the intake after the engine was shut off when hot. The vapors would be drawn back into the engine when restarted and burned. Ford deleted this from production as of 4-4-05. The PCM calibration was not changed. My 05 did not have this (built 5-5-05) so I contacted Ford's tech hotline. Got the above info straight from the plant engineer. Hope this helps.
05 GeeTee
34
#13
  • Jun 29, 2005
  • #13
The trap is after the MAF and it's a vapor trap not a air straightener.
BlazerLT
29
#14
  • Jul 8, 2005
  • #14
Ah, ok, because on some of the GM MAF's, they have a screen on the upstream side to straighten the airflow path so the MAF doesn't take a reading from a turbulent air mass passing through.
But seeing it is after the MAF, who cares right.
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
