  • SN95 4.6L Mustang Tech
intake wistle...
  • Thread starter Thread starter Bruce Steagall
  • Start date Start date Aug 17, 2008
Bruce Steagall
Rochester NY
Aug 17, 2008
  • Aug 17, 2008
I have a trick flow upper plenum BBK 70mm throttle body and cold air by BBk.The throttle body wistles and is there anything that can be done about it? Thanks
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Aug 17, 2008
  • Aug 17, 2008
My intake does the same. It doesn't really bother me though. Its probably due to the type of filter aftermarket intakes use.
topgunz_1
100
Louisiana
Aug 18, 2008
  • Aug 18, 2008
it happens, since you dont have the super restrictive intake on anymore, those kind of noise can escape. The only way to stop is go back to stock lol
fudleyd
180
Littleton, CO
Aug 18, 2008
  • Aug 18, 2008
I noticed a very pronounced "whooshing" sound when I did my plenum upgrade, I kind of like it.
J
juecke98gt
Banned
May 31, 2008
78
  • Aug 18, 2008
Mine to I like it also
blckstng96
208
  • Aug 18, 2008
yup,this is common.the stock setup is designed to eliminate those types of noises,i kinda like it too haha,you can actually hear that your parts are working haha
G
GettinThere
553
Central Texas
Aug 18, 2008
  • Aug 18, 2008
I also have a Trick Flow "plenum" with the stock tb and the stock air intake tube. Mine whistles, kind of like blowing across the top of a Coke bottle. It's a faint sound, mostly audible at part-throttle.
I'm about as sure as I can be that there are no leaks. I really think it's the design of the plenum that causes this whistle.
silver04GTstang
35
  • Aug 18, 2008
mine whistles constantly and i love it.....it did it really bad when i had just the 75mm throttle body and stock plenum....then i ported the stock upper plenum and it quit and i was sad....then i sold that and got the trick flow unit and started whistleing again so i was happy....i seen a buddy of mine on the interstate the other day and he calls me on my phone and says man somethings wrong with your car its whistleing at me.....then i kicked it and he said "oh..."
Bruce Steagall
Rochester NY
Aug 20, 2008
  • Aug 20, 2008
Yes, I took it to ford and it does not have a leak, it is the air by the throttle plate . rushing through the throttle plate. Said it is characteristic. and the stock one has a design for deadning the noise.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 29, 2025
General karthief
