Intercooler on supercharger....... Suggestions?
  • Thread starter Thread starter 1993SSP
  • Start date Start date Jun 25, 2008
1993SSP
1,194
Ky
Jun 25, 2008
  • Jun 25, 2008
Anyone in here running an intercooler on their vortech? I just do not like how my car runs like ass when the warm weather gets here. Are there any reasonable ways to put a intercooler on mine with the A-trim?? Not looking to spend thousands of dollars either
1991vert
1,103
Ludlow, MA
Jun 25, 2008
  • Jun 25, 2008
i am...now i know why no one makes kits for them...
1993SSP
1,194
Ky
Jun 28, 2008
  • Jun 28, 2008
Care to share info, pics?
1991vert
1,103
Ludlow, MA
Jun 28, 2008
  • Jun 28, 2008
well it's for a paxton, but same concept...
some cutting will be neccessary!
Parts:
-Intercooler
-"L" shaped brackets to hang the intercooler. Purchased at any hardware store
-3" 304 SS pipe
-1 U shaped
-3 90* bends
-1 45* bend (or you could use a 45* coupler+straight section of pipe)
-assortment of couplers/clamps
What I did was, I turned my intake around backwards so the throttle body was pointing towards the driver's side. I then routed the tubing through the apron where the washer fluid resevoir was, down into the intercooler. this is where it gets a little tricky...
now on the pass. side of the intercooler(exit) it goes into a 90* bend slanted upwards and into where the stock airbox was. this section will require you to make that oval into more of a triangle shape by grinding upwards in the center of the top part of the oval. i used a 45" coupler coming off that pipe, into a straight section, then into another 45* coupler, into the U bend, and connected that to the blower outlet. i should have pics of it all together within the next few weeks, but here's how it is for the most part...
let me know if i can be of more help
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 28, 2008
  • Jun 28, 2008
that setup looks good!
did it make much of a performance difference?
and what did you have to do with the throttle linkage to get it to work properly....
and i assume you had to extend the harness for the TPS, IAC etc etc to reach the sensors in their new locations?
I
ike34
156
12
Waterloo, IA
Jun 28, 2008
  • Jun 28, 2008
That setup looks good, I have been thinking about doing something like that for my a-trim
1991vert
1,103
Ludlow, MA
Jun 28, 2008
  • Jun 28, 2008
car can't even start yet, so i dunno lol. the cooler, the better! what i did was i turned the throttle body upside down so it was still pulling from the correct position.
i actually relocated the IAC sensor right before the throttle body. so SOME lengthening will have to be done, but in the overall scheme of things, it's the least of your worries lol
1991vert
1,103
Ludlow, MA
Jun 28, 2008
  • Jun 28, 2008
thanks, maybe i could write a more detailed write-up and have it stickied? i don't know how many people are interested in doing this
alanw6
449
memphis, TN
Jun 28, 2008
  • Jun 28, 2008
I'd be interested to see the writeup.
Your work looks great, nice job!
Foxfan88
Sep 13, 2004
2,487
Miami, Ok
Jun 28, 2008
#10
  • Jun 28, 2008
  • #10
yeah i would be interested also in a write up of the project, let us know how it runs and if it made any difference from before...
another thing, i am guessing you clocked your housing closer to the drivers side right? my vortech v1s outlet it alot closer to the passenger side and would almost be impossible to efficiently make a 180 turn to the front of the car...... i'd have to clock my housing...
1991vert
1,103
Ludlow, MA
Jun 28, 2008
#11
  • Jun 28, 2008
  • #11
yes, i clocked the housing as far as i could without hitting the valve cover
1991vert
1,103
Ludlow, MA
Jun 28, 2008
#12
  • Jun 28, 2008
  • #12
thanks man
1993SSP
1,194
Ky
Jun 28, 2008
#13
  • Jun 28, 2008
  • #13
I wouldnt have the option of turning the intake, def looks like some fab work to think about. I am still brainstorming
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 29, 2008
#14
  • Jun 29, 2008
  • #14
What intake are you running that you couldn't flip it, Typhoon? It'd go the opposite direction, if need be. You just might have issues with the oil fill tube on the passenger side valvecover. That's nothing a set of aftermarket valvecovers couldn't fix, IMO.
Edit: This one is taking a technical turn. Moved to 5.0 Tech.
1991vert
1,103
Ludlow, MA
Jun 29, 2008
#15
  • Jun 29, 2008
  • #15
he could just swap valve covers so the one w ith the fill is on the driver's side
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Forced Induction Normal intake temps for supercharger??
  • Kid wita 5oh
  • Jun 16, 2024
Fox 5.0 Mustang Tech Jun 16, 2024
Kid wita 5oh
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
