  • 1994 - 1995 Specific Tech
interior a/c fan/blower problems !
  • Thread starter Thread starter Eighty8LX50
  • Start date Start date Jul 18, 2004
Eighty8LX50
77
San Diego Ca.
Jul 18, 2004
  • Jul 18, 2004
Whats up, My girlfriends 95 gt has a small problem. When the fan or the ac is turned on it just blows all the air out of the defroster vent on top of the dash. I think it could be some valve but I dont know ? Please help !
AznStanger3v
2,026
Northern VA
Jul 18, 2004
  • Jul 18, 2004
could be a couple things:
Evaporator
Blower motor (dont think its that bc something is coming out)
Accumulator
those are my best guesses. sounds like something is clogged in the system.
SN95StangMan
1,292
Lynwood, CA
Jul 18, 2004
  • Jul 18, 2004
Its is probably the small vacum line that is under the hood. It is like 1/8" and starts out at the vacum tree by the drivers side firewall and goes across the firewall. Check that and make sure it is not loose/broken.
Eighty8LX50
77
San Diego Ca.
Jul 18, 2004
  • Jul 18, 2004
I dont know but its allmost like the switch for the fan or some valve that controls all the changes in the fan from the switch ??????????????????
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jul 18, 2004
  • Jul 18, 2004
I had this same problem it turned out to be a vaccume hose running along the firewall. Check those hose.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 19, 2004
  • Jul 19, 2004
I had the same problem. The vacuum tree is mounted near the firewall, on the drivers side inner fender. The vacuum line is broken somewhere.
When I was doing my clutch, I loosened my smog tube (long story), and broke the vacuum line. As soon as I repaired the vacuum line, the problem went away.
Scott
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jul 19, 2004
  • Jul 19, 2004
Evaporator
Accumulator
J/K bro.
Wystang and Mo are right. Look at the pass side fire wall near the heater core hoses to find that thin vacuum line. There is a connector piece for that hose around the back of the intake. The area around the connector piece is a common place for those things cracking ( although it could be anywhere). You could tape it for now, then fix it depending on the site. If it is close enough to the connector, you can just get a new connector and trim the hose where it is cut. If it's near the middle of the hose, you'll have to get a new one.
You should have done a search for this topic..it's all over the place.
Good luck
RC
Eighty8LX50
77
San Diego Ca.
Jul 19, 2004
  • Jul 19, 2004
It was the small vac line going to the tree. It was broken off in the rubber fitting. Sorry for wasting bandwith but info is allways a good thing.
94GTLaserRC
11,178
Jul 19, 2004
  • Jul 19, 2004
Dude, dont worry about Bandwidth...we're here to help..WE have a great bunch of guys in this forum over here. (except for ehhh..emmm)
RC
95snoozer
2,572
RCR
Jul 19, 2004
#10
  • Jul 19, 2004
  • #10
its just he vacuum line
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 19, 2004
#11
  • Jul 19, 2004
  • #11
RC
:clears throat:
Scott
D
AC Circulation
  • Dtn520
  • Jun 26, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 27, 2026
LILCBRA
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
A/C blowing defrost
  • 70/04mach1
  • Jul 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2025
