Hi I have a 89 5.0, mostly stock. I am having some troubles with the electrical and was wondering if anyone could give me some tips on how to fix it.
It all started with a problem with my alternator. That has been replaced and so has the battery. But now when I test from + on the battery to the frame I get 0volts and - to frame I get 12volts. Which would tell me that I have a short somewhere. I have checked everything and there is nothing visible that is shorting so now I am thinking there is a relay or something that is fried. I can remove the yellow lead with the fuse links going to the cab of the car from the solenoid and the short goes away. Now the strange thing is if I connect a battery charger directly to the yellow lead sometimes everything powers up and sometimes it doesn't. If it does I can then connect the lead back up to the car and it will crank over and work like normal for a few seconds. Then it starts all over again. I have replaced the solenoid once already. I can disconnect the ignition module from the steering colume and it doesn't change a thing. I have no power to the dome light or the hood light or anything inside the car when it quits.
I have done alot of thing so I may have missed mentioning them here but I welcome any and all ideas.
Thanks.
Thanks.
