  • SN95 4.6L Mustang Tech
intermittent check engine light – P1443
  • Thread starter Thread starter '89cab
  • Start date Start date Dec 21, 2005
'89cab
Carmel, CA
Dec 21, 2005
  • Dec 21, 2005
The check engine light comes and goes on my son’s ’96 GT. Originally, it was on all the time. OBD scanning indicated P1443 – Evaporative Emission Control. Starting with the cheapest stuff first, I’ve replaced the PCV valve, Purge Flow Sensor, and the gas cap. I also changed the Idle Air Control valve because of losing idle (had cleaned it a year ago).
Now the light is more on than off and I’m not sure how to check other sensors and hoses let alone what order to start looking. Any help? Thanks.
Mike
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Dec 21, 2005
  • Dec 21, 2005
Not sure about the '96, but my Mom has a '95. One of the more common things, other than the IAC valve, is the DHCP sensor (EGR valve position sensor) going bad.
Other things to consider:
EGR valve
EGR valve solenoid
Vac. leak
Good luck
Pearl02
496
Kansas City
Dec 21, 2005
  • Dec 21, 2005
EGR valve
EGR valve solenoid
Vac. leak
Good luck
Yea, that's probably your problem. The sensor is called DPFE sensor. They get corroded inside. It will cost around $70.00. Pearl02.
blackfang
1,290
Richmond, Va
Dec 21, 2005
  • Dec 21, 2005
Have you checked the charcoal canister that is part of that evap system? That and the valve related to the charcoal canister. 90% of the evap codes we have pulled at work are either gas cap or the canister and or the valve.
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
