Intro/questions
4cars2parkingspots
Hello everyone, my name is Brad and in located in the southern NH area. The car is a 1990 medium cabernet lx convertible fox 5.0 with a 5 speed. I've had the car for about a year and a half and it's been a great car especially considering i picked it up fairly cheap ($1,300). I picked the car up from the third owner and it seems like each owner kept pretty good records of the cars history.
The car is in really good shape, minimal to no rust and some basic mods (BBK header, H pipe and intake, MSD distributor and ignition, Violator muffler, sub frame connectors and some Cobra reps). The interior is all there, except someone along the line removed the door pockets. This car was definitely taken care of and was/is a good base for a project.
Anyway, now to my issues lol. I pretty much daily drove the fox on every nice day until the fuel pump went out. I let the car sit for a couple months before I was able to get around to replacing the pump. While i was in there i upgraded the pump to a Walbro 155 and also changed the bracket, sending unit, lock ring and gaskets. I was actually pleasantly surprised by how easy it was to change. All things considered i was done in about 2hrs time, not bad for my first fox fuel pump.
After changing the pump, I'm unable to get the car to fire up. I double check lines coming off of the pump and they are on the right way. The fuel pump primes and i'm getting a solid 40pds on the fuel rail, I also check and i have spark coming off of the ignition coil and on each cylinder on the top on the distributor. Timing was checked and it was perfect. The plugs looked great and the gap was right on. I'm just at a loss, and i pretty sure i burned out the starter solenoid trying to start the car this Sunday.
A couple other things to note is i don't smell any fuel while i'm trying to start the car which is weird to me. When i got the car to turn over there wasn't even a sputter or a rumble like it wanted to start. Any help would be appreciated and thanks for having me on the forum.
Try to start with the pedal depressed to the floor. This turns off the fuel injectors and helps to start a flooded vehicle. I don't expect it to work, but worth a try.
What you need to do is determine if the fuel injectors are firing. For this you need a noid light
http://www.engine-misfire.com/how-to-check-fuel-injector-pulse-using-a-noid-light/
Assuming you have 40 psi in the rail, I assume then there is fuel at the injector. So really you just need to confirm that they are getting the pulses telling them to open/close.
I agree with mustang5l5 but I will add there is a 'cranks but no start checklist' in the tech / how to threads that will help, it was put together by people that have experience with this stuff. I would post a link but I'm on a strange computer, first time I had to pull start a computer like a lawnmower.
I always do the 'back yard quickie check' quick shot of starting fluid, just a quick shot. if it starts it's fuel related.
Cranks OK, but No Start Checklist for Fuel Injected 5.0 Mustangs model years 1986-1995
A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
Revised 26-Jul-2017 to add fuse link diagram.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD, Crane, or other ignition box if present - Bypass it and return to stock configuration if possible. Do this as a temporary measure to eliminate it as a possible problem source.
B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
D.) Coil
E.) No EEC or computer power - EEC or computer relay failure
86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
F.) No EEC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
94-95 models only: Check inside fuse panel for fuse #18 blown – 20 amp [fuse
H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
You'll find it up next to the starter solenoid where the wire goes into the wiring harness
I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the Ignition switch wiring diagram for more information on the ignition wiring fuse link because it is the next thing to be tested. You will need a Multimeter or DVM and know how to use the Ohms function to check continuity between the red/green wire on the ignition coil and the red/green wire on the ignition switch. Make sure that the ignition switch is in the off position when you do the check. You should see less than 1 Ω (Ohm) between the red/green wire on the coil and the red/green wire on the ignition switch. More than 1 Ω means that the fuse link may have blown open and needs to be replaced. If you get 1 Ω or less means the fuse link is OK and the ignition switch is bad.
Wiring Diagrams:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
64326
A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
See the graphic for the 10 pin connector circuit layout.
salt-pepper-10-pin-connectors-65-jpg.68512
The injector power pin is the VPWR pin in the black 10 pin connector.
D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it, if you get this far. If it starts, replace the ECT.
From the looks of it I have to take the upper intake off to test each injector? Can you recommend a place to buy Noid light
I tried starting the car at different pedal positions and got nothing.
Thanks for the help
Sounds like the computer I use at work hahaha.
I didn’t have any starting fluid but I did try putting a little gas in the intake, it wasn’t much but maybe I’ll have better luck with a little starting fluid. I’ll have to give that a try, if I get it to fire at least that will point me in the right direction. Thank you
D.) Coil
Wiring Diagrams:
B.) Distributor cap
C.) Rotor
Two reasons:
Thank you, I’m definitely going to go through this check list. I’m sure this is going to be a big help.
I appreciate you guys taking the time to add your input and look up info. It makes this a lot easy when you have a good community willing to help.
I probably won’t be able to work on it until Sunday the earliest, I’m stuck going to a gender reveal party on Saturday. It seems like there is always something I have to go to that prevents me from wrenching haha. Not to mention I already have my hands in a few half completed projects. With any luck I’ll knock most of them out before the snow flys
You don't need to test every single injector. The front, pass side injector harness is the most accessable, so you can simply unplug the first injector and plug the harness into the noid light.
I'd run through the no start checklist first.
Here's an example of a noid test kit. I believe the local parts stores will rent these out. Unsure though
http://www.autozone.com/test-scan-a...al-tester/oem-8-pcs-noid-light-set/948078_0_0
