  • SN95 4.6L Mustang Tech
Is 4.30 gears too much?
  • Thread starter Thread starter frey_gt
  • Start date Start date Apr 16, 2008
1 of 2 Next Last
frey_gt
17
Williamsburg,Oh
Apr 16, 2008
  • Apr 16, 2008
I have a 96 GT 5- speed and I have a set of 4.30 gears to put in it. My question is, is the gears going to hurt the car more than help it? I see alot people running 4.10's in 2V's. The car is pretty much stock, BBK cold air intake, 75mm Holley throttle body, Trick Flow upper and a h-pipe with Flow Masters. I do have set of P.I. heads and cams but that will be later on once I have the money to get the heads ported. How would the 4.30's do with the P.I. heads and cams?
lvmustanggt
721
Las Vegas
Apr 16, 2008
  • Apr 16, 2008
4.30 just too much for dd but if this is your track car only then do it.
frey_gt
17
Williamsburg,Oh
Apr 16, 2008
  • Apr 16, 2008
I forgot to add that. It will mostly be a street car, it will only see the track maybe a couple times year. But it wont be a DD. It will just be something to have fun driving on the weekends.
04GTMustang
348
Stafford
Apr 16, 2008
  • Apr 16, 2008
i mean 4.30s will be fine for the street highway you will be tachin pretty high. but what are your overall plans on the car. blower? turbo? nitrous?
frey_gt
17
Williamsburg,Oh
Apr 16, 2008
  • Apr 16, 2008
My plans right now is n/a. I just want to see how fast I can get the car with fully ported heads and a good set cams with suspension and a strong manual tranny and as much weight as I can take out of the car.
04GTMustang
348
Stafford
Apr 16, 2008
  • Apr 16, 2008
well heck if you are going cams then 4.30s will be a very very nice gear because then you just raise the limiter and then the 4.30s will be nice cause it will get ya in that power band very quickly and keep you there.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Apr 16, 2008
  • Apr 16, 2008
4.30 gears is too much for an NPI car. The powerband is way shorter than a PI car.
D
Dragstr05
643
Stafford VA
Apr 16, 2008
  • Apr 16, 2008
If those are your plans and you stick to it, 4.30's would be a good gear for you. I know somone with a 97 cobra with 4.30's and they are awesome in his car, but he also has another 1,000rpm to work with.
04GTMustang
348
Stafford
Apr 16, 2008
  • Apr 16, 2008
yea i agree its too much gear for a NPI car because they dont breathe as well up top like the PI cars. but if he caries out his plans of ported heads and a nice cam then 4.30s will be nice with a higher rev limter. If you keep the stock limiter then 4.30s will still probably be too much and a 4.10 would be better because u would be shifting too much and not really using the full power band.
frey_gt
17
Williamsburg,Oh
Apr 16, 2008
#10
  • Apr 16, 2008
  • #10
Thanks for the replys everyone. But that is my main plan right now to just run n/a. I just hope my bottom end holds up. I was going to go ahead and put the 4.30's in with 31 spline axels and I already have the 31 spline carrier. I was going to do this all at once and get it over with. Then after that get my P.I. heads ported and a set of cams.
StangYellow
1,052
Apr 16, 2008
#11
  • Apr 16, 2008
  • #11
Your t-45 trans has a .67 overdrive as compared to the .62? tr-3650. As far as living with the gears, I think you will be fine. My 02 runs around 2700rpm at 70mph. You would probably be around the 3000 range.... (im guessing). Problem is, a non-PI 96 GT isnt going to make great use of the higher RPMS. If it were my car, i would install them regardless.
Mossberg
ATL, Shawty
Apr 16, 2008
#12
  • Apr 16, 2008
  • #12
I say 3.90s or 4.10s would suit you well.
98bluevert
130
Mattoon, IL
Apr 16, 2008
#13
  • Apr 16, 2008
  • #13
I just had 4.56's put after my 4.10's chucked a ring bolt. i have a 98 and i love them i just need better tires now. also have PI cams and intake. not a d/d. right at 3000 rpms in 5th at 70 mph.
Winters98GT
1,291
224
H Town
Apr 16, 2008
#14
  • Apr 16, 2008
  • #14
Your gears are not very usefull unless you're planning on a serious power and 28 inch tall rubber, or like to play in the mud.
frey_gt
17
Williamsburg,Oh
Apr 17, 2008
#15
  • Apr 17, 2008
  • #15
The 4.30's with my non P.I. heads and cams will only be for a short while. I would say around the end of summer I will be able to get the heads ported and buy some big nasty cams.
Winters98GT
1,291
224
H Town
Apr 17, 2008
#16
  • Apr 17, 2008
  • #16
you're going to hurt your performance unless your running a 15 inch tire and launch high at the track.
frey_gt
17
Williamsburg,Oh
Apr 17, 2008
#17
  • Apr 17, 2008
  • #17
Even with ported P.I. heads the 4.30's would be hurting performance?
Winters98GT
1,291
224
H Town
Apr 17, 2008
#18
  • Apr 17, 2008
  • #18
yep. The only gain your going to see with 4.30's is with a 15 inch wheel with dot radials or slicks. Otherwise, its just wheelspin. You really need a sidewall with that low of a gear.
frey_gt
17
Williamsburg,Oh
Apr 17, 2008
#19
  • Apr 17, 2008
  • #19
Thanks for the info Winters. You think 275/50/15's dr's would be good enough or something bigger?
Winters98GT
1,291
224
H Town
Apr 17, 2008
#20
  • Apr 17, 2008
  • #20
the gear is a streetable gear, as proven by some of the top NA guys that drove their car daily with 4.30's, as Bill Putnam did. Its just not going to provide you with any benefit on the street over 4.10's. Just depends on if its a track car that is driven on the street, or a street car that sees the track on occasions. 4.10's in a 5 speed NPI is plenty gear, you just run out of usable rpms so quickly with them or anything more.
Check your PM's.
1 of 2 Next Last
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
