Is an 8" better than a 9"?
67MustangManiac
67
Rear axle, that is!!
I'm debating rear selection for a 67 Stang. Everything from TBird IRS to 9 and 8 inch rears. Been reading and found out that an 8" rear is 100lbs lighter than a 9"!! That's a LOT of unsprung weight.
http://www.fordmuscle.com/archives/1999/12/lockright/index.shtml
Any downside? I see positive traction devices are available as well as several gear ratios.....interesting! Why SHOULDN'T I use an 8"?
thanks
Maniac!:banana:
The guy who said the difference is more like 25lbs is right. I know lots of people who used to believe the 100lb difference myth, but it just isn't so. Unless you plan on hammering the car, or putting some serious rubber on it and drag racing it, I wouldn't worry about it. I know someone will likely post about how weak they are, but until you break something, don't sweat it.
:shrug: :nonono: an 8.8 inch rear end found in a turbo coupe will hold tons of power it all depends on your posi setup, i run over 700 hp through it, there is no use for a 9" unless your running crazy power doing wheel stands w/slicks.
He's talking aobut an 8", not the newer 8.8
nmk_61802 said:
my understanding was about 25lbs difference between the two.
I thought that sounded like an enormous difference...I wasn't sure where they could have saved that much. ( I helped someone remove a 9" out of an LTD just yesterday) If it weighed 100 lbs LESS...that'd be pretty light!
This will be for a Shelby 350 clone, 289 (or 5.0), Toploader 4 speed. It will see the occasional drag strip pass but mostly a cruiser.
Hey Hearne!! Find an 8" for me!!!:D
thanks y'all!
Maniac!:banana:
