Is factory h-pipe stainless?
Thanks everyone, I figured it probly wasn't but I took it off after 19 years and its got some surface type rust but nothing serious. Maybe because that part of the exhaust runs so hot and it seems like pretty thick tubing.
Yes I believe the only company that sells a stainless unit is bassani, and even then I think only the cats are stainless. I could be mistaken...Magnaflow also uses "stainless" mufflers and tips. I can't see ford using anything better than cheapy steel
To clarify, all metals (except a few like gold and aluminum) Rust, Rust is iron oxidation, Gold oxidizes and so does Aluminum, but not the nasty rust we see on our car parts.
Stainless steel is simply less prone to it because of the metals that go into it. Any imperfections in the finish would yield crevices that would hold moisture and dirt etc, and this would eventually lead to rust even in stainless steel. There are different grades of stainless steel. Some magnetic some not, mostly non-(used in hospitals and food grade cutlery). But there are still true stainless metals that are magnetic, as far as the stock h-pipe is concerned, I cannot recall exactly, I merely wanted to explain that it is possible.
You mean 440 stainless??
It's used in swords because it's hard as hell when heat treated...but not really desirable in a functional sword. Carbon steel is a little more desirable if you plan on fighting in the Crusades with it.
