Is Mobil 1 75-90 Gear Fluid Recommended
  • Thread starter Thread starter BNAZ
  • Start date Start date Jun 2, 2005
BNAZ
52
MA
Jun 2, 2005
  • Jun 2, 2005
1 Have About 500 Miles On New 3:55 Gears. I Bought Mobil 1 75-90
And Another 4 Oz Of Friction Mod. Is This Gear Fluid Good Or
Should I Find The 75-140.
HISSIN50
34
129
Jun 2, 2005
  • Jun 2, 2005
The 75W-90 is closer to the weight that is 'recommended' per the service manual. I would think that weight should be fine, and it will do you a little better in the winter than the thicker stuff, IMHO.
Good luck.
BNAZ
52
MA
Jun 2, 2005
  • Jun 2, 2005
Thats what I thought. I was concerned about using synthetic cause its a 90 w/135k but I replaced clutches and seals with new gears.
Thanks
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,356
208
114
Ohio
Jun 2, 2005
  • Jun 2, 2005
I am pretty sure 80W-90 is what is called for in the rear end.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
stangnet.cardomain.com
Jun 2, 2005
  • Jun 2, 2005
I recently heard that Mobil-1 may now include the friction modifier. Might want to check out their website or go over the bottle closely to find out if you still need to add it.
8950HO
658
  • Jun 2, 2005
I`ve been using Mobil 1 75w90 gear oil since the early 90`s in my 89, 5.0L without the Ford friction modifier,(I don`t think it`s necessary with this gear oil),without any problems to date,not even a leak.
HISSIN50
34
129
Jun 2, 2005
  • Jun 2, 2005
FWIW, next change I will be running straight 75 or 80W-140. The charts on Redline's site are kind of interesting. IIRC, the syn 75/80W-140 flows BETTER than dino 75-90, so WHY not.
It is very very hot where I live - I might not do this in a climate where the stang is driven in temps below 50*F or so (I did not read the charts with concerns for cold temps).
But for you warmer climate guys, something to consider.......
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
P
Hello, core supports for '86 vs '90-3, i need some answers if anyone knows
  • Pony Dr.Mike
  • Mar 14, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 15, 2026
95steedamustang
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
