Is there a how to section?
  • Thread starter Thread starter MY 85 GT
  • Start date Start date Nov 15, 2008
MY 85 GT
1,852
208
104
New Jersey
Nov 15, 2008
  • Nov 15, 2008
Is there a how to section on how to remove the lower dash panel and also to remove the trim/panel to say get to the speedo...gauge area?..this is on my 93 i want to mount a toggle switch were they have an alarm light right now...its a dead light not being used so i figured i could just drill tat hole open a little larger and mount my switch there...thanks....
1990_LX
38
  • Nov 15, 2008
To remove the trim panel around the gauges(the one that houses the light switches) you have to take the 2 screws out of the top, by the windshield. Then you need to take the 3 bolts out of the bottom dash trim pannel(the area that would be above your knees when in the drivers seat) and with them removed, pull gently(there are 2 clips on the top part). With that removed, you'll see 2 more bolts holding the dash section around the gauges. Just take them out, pull it out and disconnect the wires going to the switches. You might have to remove the colum trim pieces but I can't remember. Hope this helps, I was trying to think of the pieces you were talking about. If I'm talking about the wrong pieces, just give a little more details and I'll help again.
MY 85 GT
1,852
208
104
New Jersey
Nov 16, 2008
  • Nov 16, 2008
no you got the right pieces i didnt know how to word what i was saying good call thanks..alot..so I f i wanted to just remove the bottom panel near my Knees that has 3 bolts and clips in right? i see some clips holding it?..i just want to remove that panel to drill a hole to put in a lighted toggle switch...
1990_LX
38
  • Nov 16, 2008
yeah, to remove that panel just take the bolts out and give it a little tug..you'll be able to see where the clips go when you go to put it back in.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
  • dan50
  • Jul 18, 2026
dan50
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
