Is this a deal?
The price sounds good, almost too good, be sure you go over the car well. Run a Carfax, have a mechanic check it out (unless you are one), look it over closely for signs of damage and repairs, get under the car, ideally on a lift, and look around as well as checking inside of the door jambs and around edges of hood/trunk for signs of overspray. If all checks out then it sounds like you found a deal.
Does it have any mods? If so make sure they were installed correctly and aren't a problem waiting to happen.
