Is this a good radiator?
  • Thread starter Thread starter 65fastbackresto
  • Start date Start date May 12, 2008
1 of 2 Next Last
65fastbackresto
1,229
AR
May 12, 2008
  • May 12, 2008
http://www.partsamerica.com/product...N&MfrPartNumber=7265BCCAX&PartType=31&PTSet=A
I think its aluminum, but it dont say for sure.
I`ve got a hot little motor and the stock rad isn`t doing the job if its warm outside, and I`m fixing to add air conditioning......
Any help is greatly appreciated.
65FBE2
283
Minnasnowta
May 12, 2008
  • May 12, 2008
Thats a good rad, but for the money get a Northern alu rad. I think you can get them from Summit. They are around a $150 cheaper and actually are better built with more modern manufacturing methods. I have one in my 347. You still need a good fan and a shroud will help. I can sit in traffic all day and never gets over 200.
Looks like they private lable them for Summit. By the way this is a built in the USA product
http://store.summitracing.com/partd...908331+4294908282+4294924707+115&autoview=sku
65fastbackresto
1,229
AR
May 12, 2008
  • May 12, 2008
That one is almost half price of the other one.
I`ve heard good things about the northerns too.
66Runt
680
May 12, 2008
  • May 12, 2008
Griffin makes great radiators.
Here it is at Summit for a little less money.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=GRI-7-265BC-CAX&N=700+0&autoview=sku
If you have a little more budget, and want to stay stock physical size here is a better cooling capacity:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=GRI-7-565BC-CAX&N=700+0&autoview=sku
Core size is pretty small on the stock size radiators for first Gen Mustangs. If you want good cooling, it takes a bit of modification to the radiator support, but you can fit a larger radiator in.
I'd also suggest that if you increase the cooling capacity of the radiator, that you go to a high volume water pump to keep the pressure and flow up.
I'm about 2 weeks away from putting this into my '66:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=GRI-7-568BC-FXX&N=700+0&autoview=sku
This will require some extensive modifications, but will allow me to run the supercharger and A/C, no matter what the ambient conditions are.
Good luck,
BarnStang
1,260
Hagerstown, MD
May 12, 2008
  • May 12, 2008
http://stores.ebay.com/FRED-MOTT-RACING_Cooling-Systems_W0QQcolZ4QQdirZ1QQfsubZ5QQftidZ2QQtZkm
Wow. Took me awhile to re-find this. Not sure how competitive his prices are, but he sells Northern alum rads. Found him at Carlisle selling Falcon parts.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 13, 2008
  • May 13, 2008
The grifon's are nice if you got the cash but I didn't at the time. I've got a northern and I'm REALLY happy with it. Mine took a little work because it was a universal radiator but it was like just over 220 shipped.
65fastbackresto
1,229
AR
May 13, 2008
  • May 13, 2008
66 Runt
That 2nd one you listed is NICE, I`m gonna call Advance and see if he can get that one for me. For less then $100 more then I`m paying now, I could have 1 inch thicker rad. Plus if I upgrade to bigger motor later it would still work out good.
I just called Advance and ordered the 3 inch thick one, thanks 66 Runt.
65fastbackresto
1,229
AR
May 14, 2008
  • May 14, 2008
The new Griffin is on the way.
Its the 1 1/2 tube one the runt suggested. Am I gonna need to upgrade the water pump or anything to go along with this? There is gonna be alot more fluid being moved around right?.....
Some history here, its a new build (one year old) hot little 302 with Edelbrock heads (I did not get the steam holes drilled in the block, I`m hoping that isn`t the problem). But it has a new 3 core radiator that just wont keep it cool if its warm outside. I`m adding air conditioning soon too...
10secgoal
2,801
San Diego
May 14, 2008
  • May 14, 2008
Didn't see it mentioned, but the Northerns aren't direct fit. You have to mount them. And any that I've sen don't have a cooling section for an auto. but I couldn't tell if you needed it by your sig.
65fastbackresto
1,229
AR
May 14, 2008
#10
  • May 14, 2008
  • #10
10secgoal
The griffin I mentioned is direct fit, I was just curious what else I may need to do while I`m tearing stuff down.
I haven`t been able to cool this car very good since I got it, I think when you run higher ccompresion and a larger cam, that maybe you generate a little more heat then a stock radiator can handle, but I`m guessing, I`m a newbie to this car stuff.
I just thought with more coolant in the system that I might need a water pump with more capacity, but I dont know.
66Runt
680
May 14, 2008
#11
  • May 14, 2008
  • #11
That radiator will be a nice fit.
As per my first post, I'd recommend a high volume water pump and you may want to look at a high volume thermostat as well. Two other things you may want to consider.
One is opening up the lower valance (like the fiberglass Shelby "R" style, or Terilingua with the cutout) that allows much more air flow over the radiator.
Second would be to add an external transmission cooler. Transmission fluid life is directly related to heat. Above about 175*F transmission fluid starts to loose it's life span. I was taught (years ago) that every 20*F above 175*F effectively reduces the transmission fluid life by about 1/2.
When you add the A/C condensor, keep it to within 1/2" of the radiator core to prevent turbulence between the two.
Good luck!
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
May 14, 2008
#12
  • May 14, 2008
  • #12
17" blues
If you want real cooling on your 65-66, you're better off moving to the 67 20" radiator in alum. More air and water volume.
66Runt
680
May 14, 2008
#13
  • May 14, 2008
  • #13
I had been debating on whether to cut up the stock support and fabricate a new "cone" or weld in a '67 core support.
I Just looked at the picture of your radiator and support, and made up my mind, it's worth replacing the core support.
That's a very clean install Jay!
mdjay
Premium Sponsor
Dec 9, 2003
896
Las Vegas, NV
May 15, 2008
#14
  • May 15, 2008
  • #14
Thanks for the compliment. You'd be surprised how many people blow by that. It just looks stock and you forget what year you're looking at. It's a more extreme route to take, but worth it if you need that kind of extra cooling to go to the 24" rad. The hood line is identical. The only issue is a little fill needed around the battery tray, and your hood latch will sit a bit higher so the hook on you hood will either have to be modified or removed. Currently have the engine out right now so I decided to make the core support bolt in and out in the mean time.
65fastbackresto
1,229
AR
May 20, 2008
#15
  • May 20, 2008
  • #15
Hey 66runt
What is the Terilingua thing your talking about here.
Also have general question about the griffin, does it take a 16 lb or 7 lb pressure cap? I`m looking at billetspecialties website.
iskwezm
4,159
20
79
Rowland Heights,California
May 20, 2008
#16
  • May 20, 2008
  • #16
youcan also cut your support, thats what I did on mine, the radiator goes from frame rail to frame rail
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 21, 2008
#17
  • May 21, 2008
  • #17
When you cut the core support do you need to reinforce anything at all or is what you removed not very structural ?
iskwezm
4,159
20
79
May 21, 2008
#18
  • May 21, 2008
  • #18
it is a little weaker, but because my paint cant be matched, i didnt reinforce mine.Its been fine for a few years now, dont see any cracking or anything.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
May 21, 2008
#19
  • May 21, 2008
  • #19
If I end up doing that to mine I'll provably have enough front end reinforcement anyways so I don't think I'll have to worry about it. Good to know you havn't had a lot of problems, especially with all that torque you got =)
04mustang70
88
Twin Lakes, WI
May 22, 2008
#20
  • May 22, 2008
  • #20
Check out the seller Fabianbatista on ebay. I bought a 2 core aluminum radiator w/ trans. cooler for my Mach1. Got it for 210 dollars including shipping. Took it to a reputable radiator shop to get it pressured tested and the guy couldn't believe what I paid for it.
1 of 2 Next Last
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
