Is this possible?
  • Thread starter Thread starter bdepedro
  • Start date Start date Mar 4, 2007
First Prev 2 of 2
strange65
71
#21
  • Mar 6, 2007
  • #21
I will bet it all. They came close but it was not Ford. Say you got the fastest car ever. On it first outing at the salt flats, this car broke records that had stood for 30 year's.
All with a "289". You later sold this car, and the millionaire that bought it complained about how expensive it was to keep it running. I lived thru this era, gas was 25 cents -thirty cents tops. 289's were cheap. Almost everything ford/mercury made then- had them falcons, comets, mustangs , cougars even.
Not going to mention name's so you fill in the blanks.
Keep in mind, if you take a 289/302 throw a 2x4 setup on it and you got one wasted carb. Do this on a 377 and it would make sense.
By the way the Australian 351 XE block will bore out to a stroker 377, the De-Tomaso (pantera) crowd can verify this.
Tech links:
http://www.carmemories.com/cgi-bin/viewexperience.cgi?experience_id=869
http://www.carmemories.com/cgi-bin/viewexperience.cgi?experience_id=868
If anyone wants the rest of the story, I guess it be better, if we take it over to the talk section.
brianj5600
1,964
Middle TN
Mar 7, 2007
#22
  • Mar 7, 2007
  • #22
Is there a single part that interchanges between a 351c and a 289? And why the links to cleveland info?
351carlo
267
Philadelphia
Mar 7, 2007
#23
  • Mar 7, 2007
  • #23
The reference to a 377 cubic inch motor.....
This was a very common Cleveland size as the crank would be offset ground to a 3.7" stroke I believe. This was before the common stroker kits and nowadays 393's and 408's are the common place.
As for a 351w crank, heck pull the pan and measure! No point in speculating, and you might as well know what you're working with.
bdepedro
362
Outer Banks, NC
Mar 7, 2007
#24
  • Mar 7, 2007
  • #24
Yep, that's exactly what I'm going to do. I'll let you know what I find. Thanks again.
bnickel
5,640
lubbock, texas
Mar 8, 2007
#25
  • Mar 8, 2007
  • #25
pretty easy to make a 377 out of a 351w. offset grind the 351w crank, use Mopar 360 rods and custom pistons and there you go. you can do the same thing with a 351C but not with a 289/302 block.
First Prev 2 of 2
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
T
Engine 1970 302 boss block
  • TOM B
  • Jan 4, 2025
Classic Mustang Specific Tech Jan 14, 2025
lqbbe
L
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
