is this supposed to happen??????
  • Thread starter Thread starter jimsstang91
  • Start date Start date Dec 24, 2005
jimsstang91
101
  • Dec 24, 2005
i checked my timing and pulled out the connecter and the car stalled not right away i guess about 2mins . it's set at 21 with the plug in and 12 with it out. i had just enough time to check it with the plug out. it has the stage 1 trick flow package.
HISSIN50
34
129
Dec 24, 2005
  • Dec 24, 2005
That can happen - it depends upon the car, idle setting, mods, operating temp of the motor, etc etc. I would make some adjustments if you can so that this does not happen though.
Good luck.
stangincoupe89
  • Dec 24, 2005
yeah mine stalled to. i have mine set at 34 total. i set it back on the juice.
306, gt40 heads(p&p) trick flow intake(ported lower) e-cam. 1.6 rockers, 65mm tbody, msd, trw pistons, total seal rings, etc...
jimsstang91
101
  • Dec 24, 2005
what should i set the base timing at right it's 12 without the connecter.??
The Shape
2,224
East ARKANSAS Delta
Dec 24, 2005
  • Dec 24, 2005
12 is a good starting point. You can go higher as long as you don't have detonation. Higher isn't always better though, some cars react better to different timing. You pretty much have to play with it and see which your car runs best at.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
