  • 1994 - 1995 Specific Tech
is this true??
  • Thread starter Thread starter 5literstang
  • Start date Start date Apr 27, 2004
5literstang
1,374
Clark, NJ
Apr 27, 2004
  • Apr 27, 2004
i need new valve covers and wanted to go with some ford racing ones, but the guy at the ford dealer told me that it would not work on my 94 cuz the oil fill hole would interfer with the throttle body, so where can i get aftermarket valve covers?
Killercanary
The car that set the bar.
Altoona, PA
Apr 27, 2004
  • Apr 27, 2004
Yes it is true. Do a search for fox body valve covers here and you'll see what needs to be ground down and the oil fill neck needs to be bent. I beat the crap out of my stockers with a hammer and got them to fit.
5literstang
1,374
Clark, NJ
Apr 27, 2004
  • Apr 27, 2004
right now i have tick flow valve covers on but the hole is cut odd shaped and oil leaks. if i got stock valve covers, there wouldn't be any performance lose, would there? thanks
Venom351R
4,548
41
98
MAINE
Apr 27, 2004
  • Apr 27, 2004
no the type of vavle covers have no effect an anything except apperance. Im Installing Fox valve covers on mine in the next week or 2, I'll sell you my stockers if your looking for a set.
mto502
357
Ancaster, Ontario
Apr 27, 2004
  • Apr 27, 2004
Do you mean it leaks around the bottom of the filler neck where the neck connects to the cover?
If so I had the same problem. The hole wasn't drilled on the flatest part of the cover creating a slight bend where my filler neck connects, thus creating a small leak. I also had to find a baffled grommet. What a mess that made before I figured that one out. Anyway, I use that black high heat (RTV?) sealer there now and it works fine. No more leaky
5literstang
1,374
Clark, NJ
Apr 27, 2004
  • Apr 27, 2004
where can i get this black hih heat sealer!
mto502
357
Ancaster, Ontario
Apr 27, 2004
  • Apr 27, 2004
Any auto place in your local area will have it.
I got mine at Canadian Tire. I'm sure Walmart would have it as well. All you need is the small tube. I paid about $5 Canadian so in the states you'll probably get it for about 5 cents
5literstang
1,374
Clark, NJ
Apr 27, 2004
  • Apr 27, 2004
is that stuff the same as permatex?
mto502
357
Ancaster, Ontario
Apr 27, 2004
  • Apr 27, 2004
That's exactly what it is. I just went out to the garage to check.
It's called Permatex black gasket maker.
5literstang
1,374
Clark, NJ
Apr 27, 2004
#10
  • Apr 27, 2004
  • #10
i think i tried that, but it didn't come out to good, but i'm goin to have to give it another try, where do i get a baffled gromet? and do i need a breather? i have a trick flow filler tube and i would rather use that. thanks
mto502
357
Ancaster, Ontario
Apr 27, 2004
#11
  • Apr 27, 2004
  • #11
Well I got my baffled grommet from Canadian Tire as well, in the performance section. I believe Moroso makes them as well. I don't know if Walmart have them. I put the gasket sealer on the grommet before inserting it into the hole on the valve cover. This way it created a perfect seal. It cures fast so you should be OK to drive your car shortly after.
I don't use a breather because then you'd have unmetered air. I retained the stock filler cap with the tube running from it to the cold air intake just after the MAF. I rigged up a piece of hose to attach to the stock filler neck with a fitting like you'd get with a breather filter to insert into the baffled grommet in the valve cover. This allows for easy removal of the filler neck when needed.
Those Trick Flow valve covers kinda suck really. I was pissed off I had to do all this crap.
If you want to retain your Trick Flow filler neck I think for you to get the best seal you'll have to remove it and place a generous amount of this gasket maker around the entire circumference if the filler neck where it fits in the valve cover. Then just clean up the excess gasket maker around the outside of the filler neck once it's remounted on the valve cover. Either that or just find a rubber grommet like I did and rig something up.
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
