issue with blinkers
  • Thread starter Thread starter scorp69
  • Start date Start date Feb 2, 2006
scorp69
605
California
Feb 2, 2006
  • Feb 2, 2006
ok, the drivers side blinker stays on in the gauge cluster, it doesn't flicker right like the right side when you use the turn signal switch. what could this be? thanks. on 95 gt
88Stangboy
Banned
Dec 12, 2005
342
Greenville, SC
Feb 2, 2006
  • Feb 2, 2006
IM curous on this too, my drivers side stays on and doesn't flicker as yours does, but the other side flickers hyper speed. I've always wondered that.
HISSIN50
34
129
Feb 2, 2006
  • Feb 2, 2006
For lighting on the fritz (one size fits all description here), check the bulbs to ensure that both front and rear on a given side work, and that the correct wattage bulbs are used.
Good luck.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Feb 2, 2006
  • Feb 2, 2006
I had the problem with the 94 firebird I used to own. Turned out the ground to the headlamp assembly was bad. Just redid the ground the signal worked like normal again. Good luck.
5.0 con-vert
No soup for you, Joe Rogan!!!
Jun 7, 2005
244
Boca Raton, FL
Feb 2, 2006
  • Feb 2, 2006
Good luck.
That seems like it's always been the case for me. If one of any of the bulbs on that switch is out, it will cause the others to just stay on constant. Hopefully thats the problem. Nice and easy!
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
