It all adds up!
  • Thread starter Thread starter 1987stangman
  • Start date Start date Aug 6, 2008
1987stangman
684
24
  • Aug 6, 2008
Well here it is. My car I think is ready for a new motor. Lately, I have noticed a major decrease in MPG. I'm talking 12 to 15 MPG if I am lucky. Performance has suffered too. This last weekend I got into it and pulled codes, new plugs, wires, rotor and cap. Plugs looked OK but now I am getting a HUGE amount of bluish white smoke at startup and a small amount at random times while driving. Today I checked the oil and it looked good, no milk or anything out of the norm and my coolant level is perfect. The thing is though, I changed the oil one week ago and today I measured what came out and it only measured 3 quarts. It usually burns 1 quart about every 1000 miles. Engine is original to the car and had close to 170,000 on it. It has been flawless until now and I dont rag this car out.
R
Rick James
172
burlington new jersey
Aug 6, 2008
  • Aug 6, 2008
170,000 isnt bad at all if its burning it and not leaking it might be time to buy a nice new engineYou should do a leak down test or a compresion test,that will tell you if you need rings or maybe just valve guides.
1987stangman
684
24
  • Aug 7, 2008
Yea, I'm going to do a leak down this weekend. I am 100% sure it is all in the heads though now. It is funny how fast things progress though. I went from a great running engine to one that eats oil as fast as gas and now performance to boot!
R
Rick James
172
Aug 7, 2008
  • Aug 7, 2008
If you wanna play,you gotta pay.Usually i pay by losing sleep,skin on my hands and my mind.lolIf its in the heads then you pick up a nice set of aluminum ones
seijirou
2,417
DFW
Aug 8, 2008
  • Aug 8, 2008
Definitely do a compression and leak down test. Smoke at startup almost always means valve seals however, as oil will dribble past the valve seals as the car sits overnight.
High vaccum situations, like coasting in gear down hill, can suck oil past the valve seals and give you some smoke once you step on the throttle again.
This really shouldn't affect your fuel mileage though. But, it would be a shame to drop the coin on a engine rebuild just to find that your smoke problem is in your heads and mileage problem is somewhere else.
You can do a poor-mans blowby (bad rings) check by pulling off your oil cap. If it's smoking at you it's an indication of possible ring seal issues.
FWIW I've got an 88 351w bronco with 230k miles and it's got like-new compression. These small block windsor engines rarely wear out at 170k when they're properly maintained.
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Tuesday at 5:36 PM
AeroCoupe
