  • SN95 4.6L Mustang Tech
It's alive!!
  • Thread starter Thread starter HIGDON
  • Start date Start date Nov 14, 2004
H
HIGDON
241
Ft. Hood, TX
Nov 14, 2004
  • Nov 14, 2004
Well after braving the 40 degree air and rain this morning the stang is up and running. There aren't any leaks from what I can tell, except for the EGR hole which blew out its JB weld plug..I'm going to just cap it with a pipe cap. Now it runs great up top but it seems to have a low end miss in it. It's too cold and still raining outside for me to go check it out, I feel I may have fouled a plug. I got a little overzealous during my oil change and put too much in, it started and smoked, so I got back under there and let a little out (should of checked the dipstick huh?) Now there's no more smoke but it misses down low. I can't wait till it's dry outside and I can really get on it...the car feels MUCH stronger!
GreekStang85
485
  • Nov 14, 2004
Cold air does wonders for our stangs
H
HIGDON
241
Ft. Hood, TX
Nov 14, 2004
  • Nov 14, 2004
So does a set of P&P'd PI heads
H
HIGDON
241
Ft. Hood, TX
Nov 14, 2004
  • Nov 14, 2004
Eh, just a thought...could the fact that the hole for the EGR is open cause the low end to feel kinda soggy and/or like a miss? It just feels like it's running REALLY rich down low, however without excessive fuel smell. I dunno, just thinking about it...Any ideas?
9
98laseredgt
122
indianapolis
Nov 14, 2004
  • Nov 14, 2004
i know after my PI intake install the egr wasnt tight and and the car idles kinda low and lobed like i had some big cams. it was cool, but come to think of it, it did miss a little i believe when i revved it. but i never drove it like that.
nate
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
  • Nov 15, 2004
Are you talking about the EGR connection at the exhaust manifold(pipe to manifold) or up on the plenum(valve-plenum)???
9
98laseredgt
122
indianapolis
Nov 15, 2004
  • Nov 15, 2004
my bad, on the plenum. i might also add that my car still hesitates at low rpm. but not as bad. it was horrible with the EGR tube off.
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
  • Nov 15, 2004
Well, I've since capped the EGR and narrowed it down the a misfire on cyl #8. .don't know what it is.....
CanadaStang
2,093
Mb
Nov 15, 2004
  • Nov 15, 2004
Glad to hear the operation went well. You had the PI intake and Pi cams before, I think right? I'm curious to see how much difference the PI heads will have over just the intake and cams.
As for the miss, did you have the #8 plug out?
H
HIGDON
241
Ft. Hood, TX
Nov 15, 2004
#10
  • Nov 15, 2004
  • #10
Yeah, I had the cams and intake before. I checked the plug. The insulator was dark brown (from what I could see in my headlights) and it was pretty dirty, it didn't look oily as far as being wet is concerned.. It's a brand new plug. I took some fine grit sand paper and cleaned it up an it's still not firing. I'm going to try a new plug tomorrow and see how it goes.
CanadaStang
2,093
Mb
Nov 15, 2004
#11
  • Nov 15, 2004
  • #11
Ya, it's no fun working on your car outside in the cold, I'm suprized you checked it out as much as you did. Hopefully it's just the plug, maybe some antifreeze or crud from the headswap fouled it. I guess just check the easy stuff 1st, and go on from there.
Did you do the EGR delete the same time as the headswap, or did you have the car running after the headswap and then do the EGR? I like to try and do just 1 mod at a time in case there is a problem, so it's a little easier to track down, but sometimes things just don't work out that way.
Congrats on the new headswap.
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Saturday at 7:48 PM
AlexM556
A
