Its time to rebuild the rear end...what all will I need
Ryan02Stang
1,181
43
Arlington Heights, Illinois
After about 100 passes on 315 Nitto Drag radials dumping the clutch at 4000 the rear end is acting up. I'm pretty sure I blew the posi. My knowledge isn't very good when it comes to rear ends so sorry if any of my questions are stupid. I'm going to redo the whole thing. I plan on buying the 31 spline moser axles. Do these axles use C clips? I think I'm going to go with a powertrax differential...what do you guys think of this unit?...also, does it come with a limited slip? So is there anything else I am going to have to buy besides the axles, differential, and c clip eliminators??? Thanks a lot for the help guys!
lol i blew mine on my 15th pass!!! You will need a new differential... I chose a 31 spline eaton, you will need new axel splines...I chose moser 31 splines and if u want to while your in there throw in some better gears!
Damn your lucky. I blew my rear end on the 12th pass on 275 nittos. And i mean it blew. I grenaded the differential. Metal everywhere once the cover was popped. And I broke a passenger side axle. The car could not be pushed off of the track. the track techs had to get a floor jack and push the car on the jack to get it off of the track.
Josh
Josh
So what kind of setup are you running now???
