jacking engine up by the oil pan
DCjuggalo
169
Charlotte, NC
hi i am changing my motor mounts, i put a 2x4 under my oil pan and started jackin it up but the oil pan started flexing some, is this normal? im guessing im doing it right (first time) what should i do, im using the oil pan section thats closer to the back of the car, am i suposed to be using the part thats closer to the front?
You should not be flexing the pan, make sure you dont destroy it. You have the bolts all the way out? Maybe you need to take the tranny mount loose too. Its a good idea to replace it anyway when doing motor mounts.
I took the transmission out of my car, i supported the engine on the oil pan w/a bottle jack and block of wood. It seems to be working fine for me even though i've had it jacked up for about a month.
