Jegs Timing Pointer Screwed Up?!
  • Thread starter Thread starter wild50gt
  • Start date Start date Sep 9, 2004
W
wild50gt
51
nj
Sep 9, 2004
  • Sep 9, 2004
so heres the deal, i'm putting my engine back together and i put my stock balancer and Jegs timing pointer on... now the motor is set to TDC and the pointer is a 10* pointer for stock motor. shouldn't the pointer be set to 10* now? if you look at the pic, specifically at the very top you see the 1st timing mark on the balancer which is no where close to 10* advanced. some one please help? thanks.
-terry
393Bird
244
Clarksville Tennessee
Sep 10, 2004
  • Sep 10, 2004
If the engine is at true TDC, the pointer should be pointed at "0" 10 degrees is where the the ignition should fire at, if is adjusted to stock settings.
W
wild50gt
51
nj
Sep 10, 2004
  • Sep 10, 2004
the engine is at true TDC, piston 1 all the way up... but the pointer isnt any where near 0* even, as seen in the pic.
393Bird
244
Sep 10, 2004
  • Sep 10, 2004
If the balancer is not on "0" when the engine is at TDC, either the pointer is screwed, or the balancer has slipped.
Make sure you are at TDC. You have a FEW degrees when the piston does not move, called top rock position. Turning it very SLOW and note where the piston just stops moving, mark it. Now SLOWLY turn till it just starts to move again, mark it. TDC is 1/2 way between these marks.
The longer an engines stroke is, the more degrees there will be in the rock position. It does the same thing at the bottom of the stroke.
Once you are sure you are at exactly TDC, the lines should line up. If the damper has more than 100,000 miles on it, just get a new one. If less, you can get a degree tape, and remark it. I would guess it is the damper that has slipped between the 2 halves.
Good luck.
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • dan50
  • Jul 18, 2026
dan50
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
