ok, i just did a dry compression test a few hours ago and here's what i got:
#1: 152
#2: 165
#3: 160
#4: 165
#5: 162
#6: 160
#7: 160
#8: 150
when i did this, i disconnected the the harness going into the enertia switch as well as some other harness going into some other thing in the same place as the enertia switch except on the opposite (right) side. didn't know what it is but wanted to make sure no fuel was getting to my motor durring testing. also, i pulled the coil wire and all the plugs. motor was warmed up but it took me so long to get everything ready that it cooled down some by the time i started. and i had a battery charger hooked up to make sure it was turning over the same each time. i'm gonna try and get a leak down test done on her this coming weekend hopefully. also my car's really leaned out, fp is at 32 w/vac line connected. no oil on my plugs except a little bit on the threads on a few of them. they're just white. if i turn my fp up any more, my car falls on its face at wot. timing is at 13* or 14*, dont remember exactly. what do you guys think?
for more info, here's my other thread about my problems:
http://forums.stangnet.com/showthread.php?t=720416
thanks a ton to all that have helped.
#1: 152
#2: 165
#3: 160
#4: 165
#5: 162
#6: 160
#7: 160
#8: 150
Not they're bad, a few are just a hair lower than I'd expect for a fresh engine.
