Just installed 4.10s what speedo gear do I need?
  • Thread starter Thread starter WilwoodFiveO
  • Start date Start date Dec 6, 2005
W
WilwoodFiveO
108
VA
Dec 6, 2005
  • Dec 6, 2005
I'm on 50 resto bout to order a new speedo gear but have no idea how many teeth speedo I need for 4.10 rear gears. Please help. Thanks.
Tyler
djk8705
154
Fairfax, Va
Dec 6, 2005
  • Dec 6, 2005
http://forums.stangnet.com/showthread.php?t=539575&highlight=correct+speedometer
KK6695GT
66
Indiana
Dec 6, 2005
  • Dec 6, 2005
7 tooth drive gear with a 23 tooth driven gear.
What drive gear do you have? Good question? What rear axle gears did you have originally in the car and what was the driven tooth you took out?
Couple possiblilties.
If you had 3.08s originally and took out a 20 tooth driven, you have an 8 tooth drive gear. Bad because you have to pull the trans tailshaft to put in a 7 tooth drive gear for the 4.10s. If you pulled an 18 tooth driven out, you already have a 7 tooth drive.
If you had 2.73s, you probably pulled a 19 tooth which again means you only have an 8 tooth drive gear.
Anthony85stang
43
Meriden, CT
Dec 7, 2005
  • Dec 7, 2005
If you have a yellow gear inside the tranny you need the white gear not sure on how many teeth it is if you have a different color gear in the tranny its either the red or black one
T
tjm73
2,418
Rush, NY
Dec 7, 2005
  • Dec 7, 2005
Tyler
I fyour '93 has the OEM tranny you need a 23 tooth speedo gear. 90-93 T5's haev 8 tooth drive gears and with that the closest you can get to correct is the 23 tooth speedo gear.
TO calculate your needed speedo gear, use this formula
(Drive Gear X Tire Revolutions per Mile X Axle Ratio)/1000
833 = 255/40R17 tire revolutions per mile
(8 x 833 x 4.10) / 1000 = 27 Tooth Speedo Gear
squeeeg
1,905
Michigan
Dec 7, 2005
  • Dec 7, 2005
You absolute best bet to be most accurate would be the 6 tooth drive gear and the 20 tooth speedo gear. The most common and close to accurate would be 7 tooth drive gear and 23 tooth speedo gear. Either way you have to change the drive gear but that is the way to go.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain Speedo gear ate itself
  • keel
  • Aug 15, 2024
Fox 5.0 Mustang Tech Aug 15, 2024
AeroCoupe
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
