  • SN95 4.6L Mustang Tech
Just wondering?
  • Thread starter Thread starter Derek1984
  • Start date Start date Oct 9, 2006
D
Derek1984
11
Spring Hill TN
Oct 9, 2006
  • Oct 9, 2006
I know that if i do a pi head swap on my 98 gt that i will have a boost in compression to 10.1 so can i still supercharger and if not would it be better to just not worry about heads and cams and just supercharge my car?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Oct 9, 2006
  • Oct 9, 2006
If you were to keep your NPI heads, intake, and whatnot and throw on a blower, your output might not be what you're expecting.
You could get a set of thicker head gaskets to lower the compression. Don't forget the supporting fuel mods, and most importantly a good tune.
Black'02
100
Rochester, NY
Oct 9, 2006
  • Oct 9, 2006
You should still be able to supercharge the car. You may not be able to run as much boost as you would if you stayed npi. Still i think you should make more power if you did the pi swap and supercharged the car with a little less boost then if you left the npi parts on and supercharged it.
D
Derek1984
11
Spring Hill TN
Oct 9, 2006
  • Oct 9, 2006
So would 8lbs be to much boost
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
My first post
  • myproGTv
  • May 31, 2026
  • The Welcome Wagon
The Welcome Wagon May 31, 2026
myproGTv
