K-Member
  • Thread starter Thread starter stangracer79
  • Start date Start date Jan 7, 2004
stangracer79
226
grande prairie alberta canada
Jan 7, 2004
  • Jan 7, 2004
What is involved when swapping a k-member?
Matt90GT
3,055
Oregon
Jan 7, 2004
  • Jan 7, 2004
pulling the old one out, installing the new one. It really is that simple
How hard is it? depends on if the motor is in the car or out of the car. Much easer when it is out of the car.
stangracer79
226
Jan 7, 2004
  • Jan 7, 2004
does it link to any suspension or is it a direct bolt-on/off?
anyone else know?
stangracer79
226
Jan 7, 2004
  • Jan 7, 2004
tttt
stang1989
211
  • Jan 7, 2004
Of course it links to the suspension. The a-arms mount to it and of course, the a-arms connect the springs and struts to the chassis. Without the K-member, you have no front suspension.
The steering rack also mounts to it. So no steering either.
pocket3799
286
Albany,GA
Jan 7, 2004
  • Jan 7, 2004
I think he's asking," Is it a fairly simple swap?"
I wish I knew, about to find out the hard way. LOL
TT91
1,536
Paramus, NJ
Jan 7, 2004
  • Jan 7, 2004
With the motor in-
1.Jack the front(not on the k-member), attach an engine hoist to motor and begin to jack motor until its obvious the weight of the motor is on the hoist.
2.Remove front wheels.
3.Disconnect steering shaft/ power steering hoses from rack.
MAKE sure nothing is wrapped around k-member, (wires, starter cable)
4.Unbolt/Remove shocks from spindles/ and from strut tower if using coil overs. USE A JACK UNDER the control arm to relieve spring tension.
5.Remove front brake lines from caliper.
6.Loosen/remove motor mounts from k-member
7.There are a total of 8 bolts, 2 on each frame rail near shock, 2 underneath neath floorboards.The k-member should break loose, once you have it out, pull it away from the car and remove the spindles/brakes/steering rack. Insert your new k-member and install with same bolts. install brakes, coil overs if using, springs, shocks, connect breake lines, steering rack....geez if u remove it and cant install it your a freakin TOOL!
This was all from memory when i did mine over a year ago, anyone else have anyhting. Total time..depends how good u are with your hands.( Im Good, really good, odds are your not).anywhere from 6-10 hrs for the average guy.
with the motor out of the car it just makes everything more accessable. ie: bolts and crap. not a hard install, good luck
pocket3799
286
Albany,GA
Jan 7, 2004
  • Jan 7, 2004
Thanks! I don't have a motor in the car.
Smokedawg
2,260
Jan 7, 2004
  • Jan 7, 2004
A pretty simple swap if the motor isnt in the car..
good luck!
-Smoke
R
Suspension Bushings for SN95 Steering Rack with UPR K Member
  • Riley Barth
  • Jun 23, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
Drivetrain 1987 Mustang notch drive questions
  • Shannonfox123
  • Apr 12, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
AeroCoupe
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
R
5.8 Trinity in a foxbody
  • Ron_ronb
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
