  • SN95 4.6L Mustang Tech
KB BAP install help (see pics)
  • Thread starter Thread starter spederman
  • Start date Start date Sep 21, 2009
spederman
732
  • Sep 21, 2009
I'm in the process of re doing the hack job wiring a worthless shop did on my car. I'm wiring the BAP before the FPDM and need to know which wire to splice into (2002 GT). According to all the threads ive seen, you cut the Pink wire with black stripe and thats where you splice in the KB BAP.
The shop that did it previously looks liked cut the pink wire with black stripe but then changed their mind, and went and spliced into the pink wire with grey stripe. The car runs the way it is, but i want to clean up the connections and redo it. Is it correct the way it is?
Also, isnt the red wires from the BAP wired backwards? Shouldnt the fused wire be spliced to the part that comes from the inertia switch and then the non-fused red wire from the BAP spiced into the part that goes to the FPDM?
Steve491
254
Charlotte, NC
Sep 21, 2009
  • Sep 21, 2009
That does kinda look like a hack job. They should never use crimp on butt connectors for something so critical, maybe a stereo speaker or a light or something, but not the fuel system.
I don't know about which wire to splice in to, maybe someone else can chime in, but I do know that the fused link is always nearest to the power supply. In a perfect world every fuse would be near the battery. In this case the fused RED wire should be hooked to the car's harness to protect the device from overcurrent (frying).
Hope this helps a little bit.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Sep 21, 2009
  • Sep 21, 2009
Hey tell me what the abreviations you are using stand for, I have the wiring schematics if you need them.
twogts4us
4,188
12
79
Dunedin, FL
Sep 21, 2009
  • Sep 21, 2009
Here is the instructions I used - worked like a charm!
I also have to agree with Steve491 - those connections should be soldered. I soldered mine, and sealed with shrink tube. Since you are admittedly cleaning up someone else's hack job, make sure you take the time to do it right.
BadMustangsClub Forums
(Apparently the site is down for maintenance...hopefully it will be up shortly)
twogts4us
4,188
12
79
Dunedin, FL
Sep 21, 2009
  • Sep 21, 2009
New Link for Bad Mustangs Club How To - INSTALLING A KENNE BELL BOOST-A-PUMP - BadMustangsClub.com Forums
spederman
732
  • Sep 21, 2009
sweet, thanks for the help guys, finally got this mess figured out an wired correct.
GDawg
1,469
Nevada
Sep 23, 2009
  • Sep 23, 2009
Gotta love Tech...!
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
T
Electrical Fox will crank but won’t prime HELPP
  • Tortoler0
  • Jul 1, 2024
3K
Fox 5.0 Mustang Tech Feb 10, 2025
bhowe2
