YellowJacketGT
- Oct 28, 2002
- 108
- 0
- 0
KB Pump Loosing Prime
Had same problems when I first intalled the KB. Would loose prime.
Replace a Vortech SQ w/intercooler with a KB.
Since the battery was still in the trunk I decided to use the larger Vortech water holding tank.
Also had priming problems.
Once I moved the pump below the tank (actually below all of the lines (lowest point)). Never had the problem, did not have to do any special priming, never had the problem again.
I believe priming issue could be reduced by relocating the pump .
THe Vortech pump was also mounted on the bottom. Never had a problem of loosing prime with it..
Picture of installation
I just got a funny mental image.
