  • SN95 4.6L Mustang Tech
Keyless Entry Probs
  • Thread starter Thread starter TheNood
  • Start date Start date Sep 3, 2004
T
TheNood
  • Sep 3, 2004
One day my alarm went off in my 99 GT and the remote wouldnt work, so I had to use the key to start the car. The alarm turned off, but ever since than I havent been able to use my remote. The keyless entry is completely out of commision. Can I reset it, or it there a real problem? Thanks
JonJon
4,801
back in Marylands
Sep 3, 2004
  • Sep 3, 2004
The manual describes how to reprogram it. If my car weren't at the shop I'd go out and type up the instructions for you...
It involves turning the ignition to ON and OFF like 8 times or something and then pushing a button on the remote. Something to that effect, it's in the manual.
J
jbrown
393
Tallahassee, FL
Sep 3, 2004
  • Sep 3, 2004
yes you put the key in the ignition and turn the car on and off about 7 times rather quickly, after the 7th time the locks should lock and unlock, than push any key on the remote.
GT-03
630
  • Sep 3, 2004
The '99 models had a factory alarm system???
JonJon
4,801
back in Marylands
Sep 3, 2004
  • Sep 3, 2004
No. It's the panic button. It sucks.
THe same situation happened to me with my car and it took like 30 seconds to get my keys out of my pocket while everyone thought I was stealing the car. I had been sitting in the car since it was cold.. and it went off for no reason.
02mingreyconv
127
Bartlett, IL
Sep 3, 2004
  • Sep 3, 2004
I had the same problem. I fixed it by redoing the programming. Turn the key from off to on about 10 times. When the doors lock theselves then you stop. Press a key on your remote and the doors will lock and unlock. Then it is 'reprogrammed'.
Good luck!
JOe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
