  • SN95 4.6L Mustang Tech
L/T removed when changing Cluch????
  • Thread starter Thread starter PSCBrenden
  • Start date Start date Jul 28, 2004
PSCBrenden
127
Dallas
Jul 28, 2004
  • Jul 28, 2004
I want to order a set of Long tubes but i have heard that they will need to be removed when it comes time to change the clutch is this true???
I am going to have to pay to have the L/T installed since that is to big of a job for myself. so i dont want to have to pay again when i need to have my clutch changed out.
V
vidmaster
167
Brick, NJ
Jul 28, 2004
  • Jul 28, 2004
i think you have to drop one side of the LT's to drop the trans.
BCB00GT
420
Jul 28, 2004
  • Jul 28, 2004
It depends on the brand
hognutz
1,940
albany, oregon
Jul 28, 2004
  • Jul 28, 2004
The hookers do not have to be removed. I assume the bassani mid lenghts do not have to be removed eitehr but that is just a guess.
BBK
mac
slp
all have to have the the pasenget side header removed from what I have read. I have not acctually insalled every brand though.
Ryan02Stang
1,181
Arlington Heights, Illinois
Jul 28, 2004
  • Jul 28, 2004
Get Hooker if you don't want to have to remove them to work on the transmission.
~B7~
369
TX
Jul 28, 2004
  • Jul 28, 2004
This topic couldn't have come up at a better time because I've been thinking about LT's a lot lately.
I was wanting Hookers, but thought about just getting BBK figuring that they'd both get the job done. But if changing out a clutch cost X amount of dollars + extra cost of most one of the headers for the install, I might just pay the extra $200 to get the Hookers that I really want.
I have a question. Can I ONLY use the Hooker off road X-pipe in combination Hooker LT's??? I'd like to keep cats on my car, but I don't know if it's an option with the Hooker LT's. BBK seems to have more mid-pipes that bolt up to it.
M
millatime
370
Palm Harbor, FL
Jul 28, 2004
  • Jul 28, 2004
the reason the hooker headers only fit with their midpipe is because it is a slip fit connection between the two instead of a bolted connection. This is also what allows you to drop the transmission and do clutch work without dropping the header. If you go with their x pipe, you can always have cats welded in
9
98SteedaStang
382
Chicago Suburbs
Jul 28, 2004
  • Jul 28, 2004
So if you go with Hooker long tube headers you have to use their mid pipe? I couldnt use a BBK off road H or an off road X? Also do the Hookers work with autos, and can I still remove my auto tranny for say, a torque converter swap with out removing the headers?
damacman
529
Phoenix, AZ
Jul 28, 2004
  • Jul 28, 2004
Just dropped the trans in mine and I did have to remove the collector on the passenger side of the Bassani mid-lengths to get it out. It was a 30 second job with a slide hammer. If I had to do it again, I'd remove both sides that would give a little more room. Still, the Bassanis fit CLOSE to the trans on the passenger side and it took some fanagaling to get the trans out and back in.
M
millatime
370
Palm Harbor, FL
Jul 28, 2004
#10
  • Jul 28, 2004
  • #10
I am 95% sure these headers work with auto trannies. You should be able to drop the trans. without removing these headers.
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 29, 2004
#11
  • Jul 29, 2004
  • #11
hooker's ought to be fine, the rest, to my knowledge may have to be dropped at least on one side
2kyellowgt
224
Nanuet, NY
Jul 29, 2004
#12
  • Jul 29, 2004
  • #12
I have the Jet Hot L/T and changed my clutch with both pipes in. The Jet Hot's are modeled after the Hookers so they should work also.
D
Drivetrain Where to place jackstands when servicing rear diff
  • dqureshi06
  • Oct 16, 2025
Fox 5.0 Mustang Tech Nov 2, 2025
limp
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Mindseye007
  • Aug 16, 2026
Mindseye007
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
squeak93
