OK, here is the deal. It was time for a rebuild of the 302 I had in my Mustang so we pulled the motor and took it to the shop. Turns out the block it shot. I have a 94 5.0 block and it is A-OK but I did not want to use the late model block. I looked thru the previous post and I have a good idea of the parts I will need…50 oz Flywheel, 50 oz balancer, old timing chain cover, Windsor-Fox clutch pivot thing for the 4 speed (has anyone ever really seen one? I can’t find them on the Wondsor-Fox web site). I have two questions before I take it to the shop:
1- I read that I could use the eccentric (The cup thing on the end of the cam that drives my fuel pump) off of my old motor to my new one. Is there anything that might not work with the new block or something that might have to be machined? I would really rather use the mechanical fuel pump.
2- I already have a Comp 270S cam for the older 302 ready to go and I would like to stay with it. Can I use the cam and solid lifters in the roller block or will I have some kind of problem with it.
It really does not matter if I use a roller cam or not. I would rather use the 270 because I already have it.
Thanks
Alex
Thanks
Alex
