  • 2005 - 2009 Specific Tech
LCA's or springs?
  • Thread starter Thread starter blbrchnk
  • Start date Start date Mar 17, 2009
blbrchnk
268
Bridgeport, WV
Mar 17, 2009
  • Mar 17, 2009
I have the option to buy some Vogtland lowering springs (1.2" F&R) for around $120 or I could buy J&M LCA's for around the same price. Which one would I notice more of a benefit from? I have searched and read that with the springs I may have to purchase a adjustable panhard and probably get it aligned, so obviously I am looking at more money spent with those. Thanks!
NastyStang113
1,567
Florida
Mar 17, 2009
  • Mar 17, 2009
The car will need an alignment without a doubt. I'd also highly recommend getting the adj. panhard bar at the very least. I'd get the lowering springs with the above mentioned before the LCAs though.
Marc S
61
  • Mar 17, 2009
I agree, go with the springs and a alignment.
blbrchnk
268
Bridgeport, WV
Mar 17, 2009
  • Mar 17, 2009
Good deal. I was figuring on getting the panhard (I would assume I want adjustable) if I got the springs. What other pieces besides shocks/struts go well in helping with the springs?
Also in regards to an alignment. How much does a full alignment cost on avg? I have never had one done.
Thanks for the help! Looks like the LCA's will be waiting a bit longer.
TBrad
91
Dallas, Texas
Mar 17, 2009
  • Mar 17, 2009
You'll need camber bolts as well with the alignment to get it perfect.
2 degree camber bolts are used for adjusting camber on the OE and aftermarket struts. The 2005+ Mustang has no camber adjustment from the factory. When lowered 1" or more, the car begins to develop negative camber resulting in premature tire wear. It is possible to gain 2 degrees of camber with one pair of bolts. If you need additional camber adjustment, 2 pairs of bolts can be used and will allow 4 degrees for a totally slammed Mustang.
Camber bolts: $39.95 pair
Alignment: around $69.99
Labor to install camber bolts around $40.00
+shop supplies $5.00
+ tax
My "Rough Guest-imate"
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Mar 18, 2009
  • Mar 18, 2009
Those springs will be more beneficial to you than the LCAs will. Springs will help the car handle much better than stock, look much better than stock and that little bit of a drop won't max out the OEM struts/shocks. I'd skip the panhard bar at first as you might not need it. Install the springs and get it aligned. Then measure the difference at the rear to see if the APB is even needed. If so, you can get a good one for less than $150 and only takes about 30 minutes to install and adjust.
blbrchnk
268
Bridgeport, WV
Mar 18, 2009
  • Mar 18, 2009
so if I may ask when they do an alignment what exactly do they adjust? And I assume adding parts like the panhard, UCAs, LCAs, shocks/struts don't affect this any?
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
