Leaf Spring Pin
  • Thread starter Thread starter Scrasauge
  • Start date Start date Sep 17, 2012
Scrasauge
118
Reserve, La
Sep 17, 2012
  • Sep 17, 2012
Does anybody know off hand what size is the center pin that goes through the leaf springs and also the length of it? Also it's on a 65 coupe
horse sence
8,419
233
Wile Coyote's stunt double
Sep 18, 2012
  • Sep 18, 2012
its 1 1/2 inches long ,5/16 bolt , with a 1/2 inch round head. i use an allen bolt
to replace them .get a grade 5 or 8. you may have to use washers under the bolt to shim it up so it will lock into the rear end pad ,you will see what i mean. if so use a 2 inch bolt. the allen bolt head is not as tall as the origional bolt.
Scrasauge
118
Reserve, La
Sep 19, 2012
  • Sep 19, 2012
thank you i never thought about using a allen bolt but i think i will go that route but i also found that summit racing has them for only $5 so i will just order them from there.
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
J
5.0 ignition wiring help
  • Jetscat7
  • Nov 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 25, 2025
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Fox 1984 GT Wiring Splice
  • handymancanfixit
  • Oct 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 3, 2025
Mcmahst
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
