Leak-off testing/Compression Testing??????
  • Thread starter Thread starter fost9508
  • Start date Start date Nov 3, 2004
F
fost9508
131
  • Nov 3, 2004
I apologize for this nub question, but it has to do with leak off testing and compression testing. I have read somewhere hear that to test for blow by you should perform a leak off test. I understand leak off testing just doesn’t test the cylinders for blow by but valves and other stuff. So….how do you know which is the problem. Also, would a compression test be better suited for testing whether or not you have blow by in the cylinders???????
Thanks in advance for the help.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 3, 2004
  • Nov 3, 2004
Putting compressed air inside the cylinders can check for all types of leakage, either past the rings, valves or head gaskets. The percentage of leakage is a function of how good a shape the engine is in. Less leakage = better engine health.
See http://jrichker.stangnet.com/Mustan...ession_tester/Blow_down_comprssion_tester.htm to make your own blow down or leak down type compression tester.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
D
Engine Questions on compression test results
  • dqureshi06
  • Jan 6, 2025
Fox 5.0 Mustang Tech Jan 7, 2025
