  • SN95 4.6L Mustang Tech
Leaking Injector??
  • Thread starter Thread starter blue46gt00
  • Start date Start date Jun 20, 2007
blue46gt00
83
  • Jun 20, 2007
Noticed at the track towards my last pass that when I would cycle the key the fuel pressure would hit 41 psi and slowly fall to 38psi. When the car is running it seams fine. Good fuel pressure. Looked for fuel leaks and could not find anything. Before the when I would cycle the fuel pump it would stay at 41psi. Any ideas?? Should I replace the fuel injectors. I'm running 42lbs injectors.
cooper58d2002
98
Hope Mills NC
Jun 20, 2007
  • Jun 20, 2007
what was the fuel level when it did it?
C
chuck943
262
north carolina
Jun 20, 2007
  • Jun 20, 2007
Does it stay at 38 PSI? That sounds pretty normal, should stay within 5 PSI for 1 minute on fuel pressure leak down test.
blue46gt00
83
  • Jun 20, 2007
1/4 of a tank. Yes it stays at 38psi
cooper58d2002
98
Hope Mills NC
Jun 20, 2007
  • Jun 20, 2007
not for sure but possible could be the secondary pickup on your in tank pump may not be picking up fuel. before you start tearing into the injectors you might try filling it to at least half a tank and then trying it. if not then maybe check the impedance in your injector harness. just a thought
cooper58d2002
98
Hope Mills NC
Jun 20, 2007
  • Jun 20, 2007
i think 7.9 to 8.1 ohms is the tolerance
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
