  • SN95 4.6L Mustang Tech
Leaky coolant sensor plug
  • Thread starter Thread starter deftsound
  • Start date Start date Dec 30, 2005
1 of 2 Next Last
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Dec 30, 2005
  • Dec 30, 2005
Well when i was installing my gauges yesterday the hexagon plug thing the stock coolant sensor plugs into popped out and i could not figure out how to lock it back into place. Now its leaking small amounts of coolant when the motor warms up and im not sure what to do. Here are pics of where it is leaking. I was thinking of replacing the rubber o ring that it has thinking that might fix it. What do you guys think?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Dec 30, 2005
  • Dec 30, 2005
pic?
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 30, 2005
  • Dec 30, 2005
T FlTTING
deftsound
Apr 6, 2004
945
Texas City TX
Dec 30, 2005
  • Dec 30, 2005
well you can see the t fitting ive already put on....whats leaking is that hexagon shaped plug that the stock sensor originally screwed into.
its leaking at the bottom of the plug right where the arrow is pointing
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 30, 2005
  • Dec 30, 2005
teflon tape, or use lightly plumbing sealant
deftsound
Apr 6, 2004
945
Texas City TX
Dec 30, 2005
  • Dec 30, 2005
yea but the plug has no threads on it. It does not screw into the intake manifold where the coolant is. It just snugs down in there and stays sealed with that o ring.
I bought a new o ring and put it on there and now i cant get the damn thing to push back into the hole so i think i must have gotten the wrong size o ring. Anyoen have any idea what size o ring im lookin for?
deftsound
Apr 6, 2004
945
Texas City TX
Dec 30, 2005
  • Dec 30, 2005
i think i may just get the old o ring and put it back on with a little silicon glue or something...
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 30, 2005
  • Dec 30, 2005
there should be threads in there right? just use a full threaded extension and add it to the fitting
04gtboy
83
  • Dec 30, 2005
t fitting wont get right temp readings the sensor is not in the actual coolant just in fitting u will low temp readings but both gauges will work if thats what u want get rid of that one and buy a brass one looks better and smaller put temp in block
deftsound
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#10
  • Dec 31, 2005
  • #10
tom it doesnt have threads, thats the whole thing i dont understand. Its like that entire piece just snugs into the hole. Even if it did have threads there woudl be no way to turn it becuase its hexagon shaped not circular.
If you look closely at the picture, it is leaking where that brass hexagon shaped plug meets the intake manifold. The brass hexagon plug part does not screw into the manifold, it just sits in there snugly with an o ring. My problem is i cant get it to stay back in there...
And i was going to put it in the block but i couldnt get the damn bolt out so i just said ***** it and used the T fitting.
CanadaStang
2,093
Mb
Dec 31, 2005
#11
  • Dec 31, 2005
  • #11
Ahh the fabbled T-fitting!! Try finding another o-ring the same as the one you took out, you may have to go to Ford to get one. I'd do that first before trying the slicone.
deftsound
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#12
  • Dec 31, 2005
  • #12
yea i think ill have too. The one i got from o reillys must be the wrong diameter or something cause i cant push it in there.Oh well, back to ford
CanadaStang
2,093
Mb
Dec 31, 2005
#13
  • Dec 31, 2005
  • #13
Hopefully they won't shaft you too bad. Just remember, a little rubber can save you alot of grief
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 31, 2005
#14
  • Dec 31, 2005
  • #14
solder that sucker on
deftsound
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#15
  • Dec 31, 2005
  • #15
well heres an update:
Went to the ford dealership and they had no idea what i was talking about. So i showed them a picture of the intake manifold and they basicly told me that in order to replace that id need to get an entire new intake manifold.
Too bad mine isnt cracked yet damnit or i could have used that recall to my advantage.
So, what i did instead is went to home depot and got the right size o ring, then i put a ****-load of jb weld on that damn plug and stuck it in there. Hopefully i wont have any problems. If i do, guess itl be an excuse to get a nice new metal intake manifold...
As soon as i get it running ill take some pics of the car since i put the lowering springs on and the new gauges...
CanadaStang
2,093
Mb
Dec 31, 2005
#16
  • Dec 31, 2005
  • #16
Hope that works!!! Give it plenty of time to harden before you start it up and hopefully it'll hold.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 31, 2005
#17
  • Dec 31, 2005
  • #17
I was just thinking, the if your intake did crack after this and knew you had that stuck on there with the jb weld they might not cover the warranty cause you know how much pricks the dealers could be
deftsound
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#18
  • Dec 31, 2005
  • #18
yea i thought about that too, if it does ill just have to do my best to make it look like its stock...
Hell if nothing else ill just save up and get one of the new performance intake manifolds that are startin to come out and get a few hp in the process
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 31, 2005
#19
  • Dec 31, 2005
  • #19
good luck to you on that
deftsound
Apr 6, 2004
945
Texas City TX
Dec 31, 2005
#20
  • Dec 31, 2005
  • #20
yup thanks, tomorrow morning ill make sure everythings dryed up good and start her up, damn jb weld takes 15 hours to cure
1 of 2 Next Last
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Issue please help
  • 4.6andre
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
